First Service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 05-22-2012, 04:31 PM Thread Starter
andreas's Avatar
First Service
Wifes Glees is due, so to save a buck she called the dealer and wanted to make sure we do not screw up the warrenty if I do the oil change myself. The mechanic was very kind to explain what needed to be done, especially changing oil, oil filter, checking chain tension, tire pressure, differential fluid, screws and bolts , etc ... He also offered to have it done in an hour or so for $170.00 ,
If you read the above twice, That is not a typo !!
FB MEMBER #133 - 2008 Wee
andreas is offline
post #2 of 15 Old 05-22-2012, 04:42 PM
mountainpete's Avatar
Are they also changing the halogen fluid and muffler bearings?
2012 DL650 EXP
Designed for outdoor use
mountainpete is offline
post #3 of 15 Old 05-22-2012, 04:43 PM
trapperdick's Avatar
Differential fluid ?? 170.00 per hr.......I did mine myself, now I'm wondering if I missed something....Differential fluid ?? ..........TD
2017 Triumph Tiger 800 XRX
2012 V Strom 650 Fox orange
2013 Yamaha FJR 1300, old mans crotch rocket
2004 Polaris Sportsman 500 ATV green
N1ATF
Spot 3
trapperdick is offline
post #4 of 15 Old 05-22-2012, 04:45 PM
You must have talked to the trike mechanic.
post #5 of 15 Old 05-22-2012, 05:35 PM
Well, if u have a service manual, and also use the owners manual, you'll probably see somewhere between 25 and 35 different things that are suppose to be done at the first service.
Most of them are just "checks", but there is a point to that. One of them would be checking the torque on the pinch bolts for the front forks. Only mentioning as one example, there are many others. But, ever heard of someone almost losing the front axle because the pinch bolt was torqued properly initially?
If you have the tools etc to do all those things, document what you did and there should be no reason for an mfg to reject a claim. But if you don't, and you don't document it... just pay the dealer. They say the first service is the most important one.
I did my own first service. Man there were quite a few things that were not torqued to specs, rear shock, swing arm bolt, handlebars, etc.
AzItLies is offline
post #6 of 15 Old 05-22-2012, 06:26 PM
My dealer charged me $50 and had the bike about an hour. I almost feel like I didn't get the whole first service as outlined in the manual. maybe I should shut up and be happy about it, a lot better than $170. I gues if parts don't start falling off the bike then I am ok.
Shiny_Simon is offline
post #7 of 15 Old 05-22-2012, 06:57 PM Thread Starter
andreas's Avatar
I bought oil and a filter, $40 plus pennies, everything else is just normal maintenance. The $130.00 we didn't have to spend will go to paying the bike off :biggrinjester:
andreas is offline
post #8 of 15 Old 05-23-2012, 01:59 AM
D.T.'s Avatar
Halogen fluid, pffft. Everyone knows it's blinker fluid. Duh.
:mrgreen:
The new V strom is tough on differential fluid so it needs to be changed. Every 6 miles I think.
D.T. is offline
post #9 of 15 Old 05-23-2012, 03:18 AM
Originally Posted by andreas View Post
Wifes Glees is due, so to save a buck she called the dealer and wanted to make sure we do not screw up the warrenty if I do the oil change myself. He also offered to have it done in an hour or so for $170.00 He forgot to tell her about enviro fees and tax,
About half the cost you're quoting in the UK for a first service. And that's from two Suzuki main dealers.
Oop North John is offline
post #10 of 15 Old 05-23-2012, 04:48 AM
1VStromNC's Avatar
Wifes Glees is due, so to save a buck she called the dealer and wanted to make sure we do not screw up the warrenty if I do the oil change myself. The mechanic was very kind to explain what needed to be done, especially changing oil, oil filter, checking chain tension, tire pressure, differential fluid, screws and bolts , etc ... He also offered to have it done in an hour or so for $170.00 He forgot to tell her about enviro fees and tax,
I would never take a bike for service to this "very kind" mechanic..just an observation.
Oil, filter change, the easiest I have ever done on a bike. Filter $10, oil $24, went over the entire bike inspect and check coolant level, and all fasteners, chain, filed my receipts.
2015 DL 650 Wee
2015 R1200 BMW ADV
"Ride as if your life depends on it"
1VStromNC is offline
