Lock Fell out of Suzuki Box latch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-21-2012, 02:28 PM Thread Starter
I've got 150 miles on my new adventure and the lock tumbler that you insert the key into on the left box fell out while riding. I looked at the other lock and the horseshoe shaped clip that holds the lock in is put in from the bottom. I think it needs to be put in from the top so gravity doesn't make it fall out. I just called my dealer and he said he would put in a warranty claim. Anyone else have this problem yet?
glastron is offline
post #2 of 7 Old 05-21-2012, 02:44 PM
nameuhpete's Avatar
Not that exact problem, but the tech at the dealer had to take one of my locks out and play around with the tumblers to get it to unlock consistently. I will look at my clips since you mention it...
2012 DL650 Adventure
1989 Goldwing 1500 (totalled)
2005 Yamaha Vstar
1981 Yamaha XS650 Special II (sold)
19?? Yamaha RD350 (sold)
19?? Honda 175 Scrambler (sold)
19?? Yamaha 80 (sold)
nameuhpete is offline
post #3 of 7 Old 05-21-2012, 02:49 PM Thread Starter
I pulled the other one out and put it in from the top so it would fall in instead of out.
glastron is offline
post #4 of 7 Old 05-21-2012, 03:23 PM
TwoShots's Avatar
Yes. Here.
[IMG]http://kolobwebstudio.com/myimages/strom_liquid_jesus.png[/IMG]
TwoShots is offline
post #5 of 7 Old 05-21-2012, 06:07 PM
r1ng3l78's Avatar
they could also be installed the wrong way. the clip should have two points of contact with the latch and one with the cylinder.
r1ng3l78 is offline
post #6 of 7 Old 05-21-2012, 10:47 PM
Remove your locks and take a pair of needle nose pliers and make sure the c clips are secure. Then get some rtv and put just a bit over each c clip and let it dry. Get some powdered graphite and inject into the locks and move the key back and forth numerous times.
Reinstall everything and you shouldnt lose anymore locks and the locks will be a bit smoother with the graphite.
140pilot is offline
post #7 of 7 Old 05-23-2012, 10:47 AM
Just checked all mine and the c clips were on tight.
Jon Kohler
Colbert, GA
2009 KLR 650
2012 VStrom 650 Adventure
IBA# 24562
LngRidr is offline
