If you bought the lower cowling, read this - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-12-2012, 06:21 PM Thread Starter
When I purchased my lower cowl, I installed it at the dealership in the parking lot. No problem after you figure out where all the parts go. However, I noticed the cowl touches the radiator hose on the right hand side at the top. This can't be good for the radiator hose long term. I pulled the top bolt and took aviation snips and trimmed a little quarter moon shape off the cowl. After an all day ride, I noticed that the radiator hose had shifted down and out a bit more, so I had to trim a little more to keep it from touching.
I think I could have achieved the same thing by loosening the radiator hose clamp where it goes into the engine and rotating the hose a bit to move it away from the cowl, however, a little trim seemed to work also.
Check your clearance on the hose. I think over time the cowl, left to rub would make a hole in the hose.
racer is offline
post #2 of 9 Old 05-12-2012, 09:55 PM
TwoShots's Avatar
Thumbs up
Thanks racer. I couldn't justify a skid plate for this bike, so I recently ordered the cowl. Appreciate your insight regarding the hose.
[IMG]http://kolobwebstudio.com/myimages/strom_liquid_jesus.png[/IMG]
TwoShots is offline
post #3 of 9 Old 05-13-2012, 01:24 PM
That's odd. Mine does't touch the hose.
rebel is offline
post #4 of 9 Old 05-13-2012, 09:27 PM Thread Starter
How much clearance do you have?
racer is offline
post #5 of 9 Old 05-14-2012, 01:27 AM
Snowkarver's Avatar
I rotated the hose slightly inwards to clear the cowl when I installed. It's been working great so far.
2012 DL650 Shiro Nakama #27
Ride Report: https://www.stromtrooper.com/ride-reports-route-sheets/79121-footsteps-lewis-clark.html
Snowkarver is offline
post #6 of 9 Old 05-14-2012, 04:34 PM
mojo34's Avatar
Mine doesn't touch either...
The guy at the shop did have a bit of a struggle fitting it in place, perhaps because of the stock bars, or perhaps he'd never done one. But the cowling seems a safe distance from the hose.
This forum's great for stuff like that... Now at 4K km I need to tighten the chain. And figure out that darn engine vibration @ 4800 rpm as discussed in another thread.
mojo34 is offline
post #7 of 9 Old 05-14-2012, 09:42 PM
reversed
Sounds like the support bar may be installed backward if the hose is rubbing. Is that possible? Mine is clear by nearly half an inch.
Odieus is offline
post #8 of 9 Old 05-15-2012, 12:29 PM Thread Starter
I just went out and pulled the cowling and I couldn't figure out how to reverse the support bar. As I recall, there is no way you could install the brackets incorrectly, they will only fit one way.
I did rotate the radiator hose while I was down there and that fixed the problem. There is no about a half inch clearance. This is probably a better solution than trimming away the cowling.
racer is offline
post #9 of 9 Old 05-15-2012, 03:15 PM
I'll take a pic later today.
rebel is offline
