'12 V-Strom 650 oil drain plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-11-2012, 08:31 PM Thread Starter
Removed the oil drain plug on my '12 650 and I was surprised to see that it is a magnetic plug. How nice of Suzuki. And I had already purchased an aftermarket mag plug, dammit. I clean and dry the oem plug and test the magnetic pull. Almost no pull force, barely able to lift a small washer. Useless.
Tony D P is offline
post #2 of 7 Old 03-12-2012, 12:27 AM
stronger magnets
A couple years ago I bought a magnetic drain plug for my KLR. I was disappointed with the strength of the magnet. It was epoxied into a recess in the drain plug so I heated it briefly with a torch and it came out easily. Then I replaced it with a neodymium cylinder magnet from K&J Magnetics. They are cheap, and are so strong you don't even need to glue it in and it stays put. So if the '12 vStrom plug has a recess in it where the magnet is you might consider that. Sorry I don't have a picture of it in the drain plug, but here is a picture of the magnet:
stromAlaska is offline
post #3 of 7 Old 03-12-2012, 12:30 AM
A magnet in an oil sump where steel gears are in contact is very appropriate. Agreed, the weak OEM magnet could be much stronger. A neodymium ring magnet on the outside of the oil filter can may be a help.
post #4 of 7 Old 03-12-2012, 01:04 AM
magnet swap in magnetic drain plug
I found a picture of it (for a KLR):
post #5 of 7 Old 03-12-2012, 01:18 AM
D.T.'s Avatar
Great idea!
Is that the magnets they use in hard drives? Those bastards are strong!
D.T. is offline
post #6 of 7 Old 05-18-2012, 11:43 PM
Where can I get such a ring magnet for the outside of the oil filter?
'12 650 V-Strom
'12 TE511
'07 Scorpa TY175
fasteer is offline
post #7 of 7 Old 05-19-2012, 10:42 AM
Search for "neodymium ring magnets". Here's one example: SuperMagnetMan
The neodymium magnets, in addition to being very strong, maintain more strength when hot than do ordinary steel magnets.
