Any way to stop the pipe from turning blue? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 03-11-2012, 09:10 AM Thread Starter
Is there anyway to stop the header pipe from turning blue?
Most Japanese bikes usually ran a pipe within a pipe so that the chrome did not discolor.
Any suggestions on how to stop this from the get go?
Mr. Pete----->
aging hippie
mrpete64 is offline
post #2 of 12 Old 03-11-2012, 09:19 AM
Keep running the engine until it turns straw colored and eventually brown. The color change is a property of the material's reaction to heat. There isn't anything practical to do about it except get a different exhaust and that with have its characteristic color pattern. There is no double wall exhaust available. The surface can be polished back to its original color by removing the microscopic colored layer using the mild abrasive in the polish. Heat the metal again and the process will happen again though.
post #3 of 12 Old 03-11-2012, 01:55 PM
kenneth_moore's Avatar
Paint them black. They'll still turn blue, but you'll never know it.
Go hakafugu yourself.
kenneth_moore is offline
post #4 of 12 Old 03-11-2012, 02:07 PM
1---Nickel plate the pipe (tough to do right on stainless; takes a very good plating shop)
2---Just ride and let muddy water bake onto the pipe (my solution).
post #5 of 12 Old 03-11-2012, 02:34 PM
TwoShots's Avatar
:thumbsup:
[IMG]http://kolobwebstudio.com/myimages/strom_liquid_jesus.png[/IMG]
TwoShots is offline
post #6 of 12 Old 03-11-2012, 03:23 PM
The fiist and only day I rode my adv.bike, I rode it 550 miles. The blue exhaust pipe looked like it was on a motor that had 50 thousand miles on it. We were amazed hot the pipe turned blue. When I ride my bike to the dealer on Tues. for my 600 mile check, it will be noted about my concern. Later next week I will put another 2500 miles on it going to and from Phoenix. HB
hardybaker is offline
post #7 of 12 Old 03-11-2012, 04:20 PM
Don't be concerned. As has been said, it's normal for single wall pipes.
post #8 of 12 Old 03-11-2012, 05:49 PM
The only single wall pipes I ever saw that didn't turn blue was on my '71 Honda with the original head pipes. But, talk about "thick" pipes...:beatnik:
[SIGPIC][/SIGPIC]"Free Men Will Never Consent To Give Up The Means Of Defending Their Liberties"
Buzzzer is offline
post #9 of 12 Old 03-11-2012, 08:53 PM
If you must have clean pipe, Bar Keepers Friend, a stainless cleaning powder does a good job.
another way was to spray a heat retardant paint down the inside of the pipe. I did that with my Kerkers back in the 70's.
post #10 of 12 Old 03-12-2012, 12:23 AM
Jet Hot and similar ceramic coatings have a polished-look 1300F coating available:
