2012 Scottoiler Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 03-02-2012, 04:19 PM Thread Starter
Hi there
Have read a few threads on this product and have purchased the V system. I've also looked at the Scottolier website for some further install tips. Overall the install looks pretty straight forward. One query I havent been able to answer yet is that to get to the vacuum connection it looks like I will need to lift the fuel tank to access the vacuum hose and route the hose to the oil reservoir ? Just thought I ask your opinions before I start the install.
Thanks again
Eddohawk is offline
post #2 of 22 Old 03-02-2012, 04:44 PM
tmcgee's Avatar
I have one on order as well. I'm planning on pulling all the plastics and the gas tank to make my electrical add-ons easier to install. I'll do the oiler at the same time.
My bike is outside under a snow covered fabric cover so I can't double check, but I seem to recall the emissions canister is located next to the seat tray on the opposite side of the bike to the drive chain. That might be a good place to tap.
tmcgee is offline
post #3 of 22 Old 03-02-2012, 06:22 PM
BrianTRice's Avatar
I am about to install a Scottoiler vSystem onto an L2 and your impression matches mine.
BrianTRice is offline
post #4 of 22 Old 03-02-2012, 06:39 PM
That isn't a vacuum canister. It's a charcoal canister that has a vent to the tank on one side and a purge tube to the throttle body on the other side. People trying to use it as a vacuum canister for an Audiovox cruise control found it doesn't hold a vacuum. There are capped spigots on the throttle bodies to be used for TBS connections that are your best vacuum sources.
post #5 of 22 Old 03-02-2012, 06:55 PM
tmcgee's Avatar
Got it -- would have found that out after taking the plastic off.
tmcgee is offline
post #6 of 22 Old 03-02-2012, 09:27 PM
Corkus's Avatar
johnofchar's VSRI scottoiler post
It is worth using Search on VSRI in this case I think.
Good luck.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #7 of 22 Old 03-03-2012, 05:12 PM Thread Starter
Thanks for the info and tips! I was wondering if the T piece that came with the scottoiler V will plug straight into the 2012 vac hose, i.e. is that vac hose the same inside diameter as the pre 2012 stroms? Thought I should check before I start cutting the hose.
Thanks
Eddohawk is offline
post #8 of 22 Old 03-03-2012, 06:06 PM
There are vacuum ports on the throttle bodies. The pre 2012 ports take 1/8" tightly, 5/32" or 4mm ID vacuum hose. I would think the 2012s would be the same. Once again, the bikes do not come with vacuum hoses, just ports. The hoses on the throttle bodies are for emissions control and can't be used for vacuum.
post #9 of 22 Old 03-03-2012, 07:42 PM Thread Starter
Ok thanks Grey Wolf, install is now complete the oiler seems to be working fine. The most difficult part was as I suspected removing the tank plastic. I found the instructions in the factory handbook to be a tad vague but overall pretty good.
Eddohawk is offline
post #10 of 22 Old 03-04-2012, 04:34 PM
markdvk's Avatar
The plastic tank sides are VERY TIGHT. I don't remember which direction they move but I had one off about 2 weeks ago. It has to slide before it will come outward. I thought it would break before it moved but it didn't.
Mark
markdvk is offline
