tapping noise when pulling off - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 03-02-2012, 02:10 PM Thread Starter
doboy's Avatar
ive got this sort of tapping noise when im setting off . it appears to come up from the front of the tank ..ive had a word with a mechanic were i got it from he says they all do that just rev it a bit more ...now ive heard this "they all do that" before so id like to know does your new wee do it as well ?
doboy is offline
post #2 of 16 Old 03-02-2012, 02:26 PM
BrianTRice's Avatar
I also am experiencing that symptom. I figured that the ABS was still initializing and might be momentarily engaging or something like that, but that's pure speculation.
BrianTRice is offline
post #3 of 16 Old 03-02-2012, 02:47 PM
It's common. I would guess the improved sound control on the lower end of the new model would make the upper end noises more noticeable.
post #4 of 16 Old 03-02-2012, 02:50 PM Thread Starter
doboy's Avatar
i dont hear it much when ive got my ear plugs in but when ive got them out its quite noticable ... just sounds like a really loose tappet [ i know it dosent have them ] , and also seems to be worse when the engines cold .. so is the older model the same ?
doboy is offline
post #5 of 16 Old 03-02-2012, 03:16 PM
It's the same in earlier years.
post #6 of 16 Old 03-02-2012, 07:07 PM
Sounds like it's either a piston return spring or a sparkplug recoil adapter.
007650 is offline
post #7 of 16 Old 03-02-2012, 07:11 PM
I get that a LOT. Normally, it's my wife...
Bob
07 Wee
10 NT 700
BobAgain is offline
post #8 of 16 Old 01-11-2013, 07:34 PM
The Wee Strom I bought ( 2008 model with 35000 klm on the clock ) also does this.
So I was really wanting to know what it is .
Done the shims , all good , tensioner and chains fine.
While poking around with my audiscope I discovered something which I think
just maybe the source.
I think it maybe well be injector hammer. Quite normal if they are clean. They tend to thud if they are dirty.
It is really loud through my audiscope with a distinct noise very similar to a tappet noise.
Now combine that with the massive chamber you have where your head stock is and I think you may find it very audible through there.
Well that is my diagnosis anyway.
Cheers Dr Dave :mrgreen:
You can always listen for your self .
astromina is offline
post #9 of 16 Old 01-11-2013, 10:30 PM
On mine it's the brake pads swinging back and forwards in the calliper.
Doesn't happen brand new as the pads havn't bedded in, but it became very noticeable when I cleaned all the dirt out of the callipers and reassembled.
Brake drag/air drag pulls the pads one way, gravity the other and 'Tik'
Pete
PeteW is offline
post #10 of 16 Old 01-12-2013, 10:28 AM
I think it is piston slap.
Juerg is offline
