OEM size electric grips for '12 650 v-strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-28-2012, 09:37 AM Thread Starter
Hello,
I am in the process of buying the new 650 v-strom. I would like to find heated grips that are standard size. I have had aftermarket grips that are like holding a large sasuage in your hands. I would also like to have the ability to vary the heat output.
I appreciate any insight(s) you might offer.
Mr. Pete----->
aging hippie
mrpete64 is offline
post #2 of 5 Old 02-28-2012, 09:52 AM
The Oxford grips I have are standard size and adjustable. I believe I have the "sport" edition.
06 V-Strom DL650
John V Strom, Jr. is offline
post #3 of 5 Old 02-28-2012, 11:33 AM
Snowkarver's Avatar
+1 on the Oxford grips. I have the Sport design too, and I think the Touring one might feel even slimmer because of the smoother contact area.
2012 DL650 Shiro Nakama #27
Ride Report: https://www.stromtrooper.com/ride-reports-route-sheets/79121-footsteps-lewis-clark.html
Snowkarver is offline
post #4 of 5 Old 02-28-2012, 12:43 PM
Penmaker's Avatar
Has anyone measured or seen published, the outside diameter of the oxford grips? The stock grips are just over 1 inch in diameter. Which for me is too skinny. I've added some foam covers but now they are too fat at 1 7/8 inch. I'd like something closer to 1 1/2 inch in diameter. Grips for sale on line only give the bar size (7/8") and sometimes length in mm (120-125mm) but not the outside diameter of the grip.
Penmaker
04 GL1800A - Traxxion suspension
11 DL650 ABS white - Lowered, Risers, Richland Rick stuff, Sgt seat, Madstad
Penmaker is offline
post #5 of 5 Old 02-28-2012, 01:32 PM
Snowkarver's Avatar
Oxford Heaterz Sport 7/8" Heated Grips: BikeSax.com - LockItt.com
According to these guys, the OD of both the sport and tour grips is 34mm, or around 1 3/8", 1 5/16". The sport Oxfords definitely feel thicker than my stock 2012 grips, but only by a small amount. Their density - harder than either the Oxford Tours or the OEM - might contribute to that.
Tags
glee , grips
