2012 - what is the rpm at true 70 mph - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 02-20-2012, 01:46 PM Thread Starter
Someone may have mentioned this before but what is the rpm of the new 2012 at a true 70 mph. Thanks.
FuzzyRider is offline
post #2 of 17 Old 02-20-2012, 03:42 PM
It is unchanged from previous years. Gearing commander says 5600rpm is an indicated 75.5mph which is actually 70mph.
post #3 of 17 Old 02-20-2012, 05:34 PM Thread Starter
Thanks again for your help.
post #4 of 17 Old 03-04-2012, 07:34 PM
Question
Beyond the position of the oil cooler, is there any other significant change between the engines of 650 2012 from the previous years?
Is there any power / torque increase between the two engines?
Pauloxxi is offline
post #5 of 17 Old 03-04-2012, 07:48 PM
Stoopy's Avatar
Which brings up a good question, is the digital speedo also ~8% optimistic, and of so how can it be corrected since you can't just throw a corrected gauge face from raceratb at it?
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #6 of 17 Old 03-04-2012, 08:50 PM
D.T.'s Avatar
Angry
The SV speedo was high, so is the new Wee??
D.T. is online now
post #7 of 17 Old 03-04-2012, 09:08 PM
ozart's Avatar
It's in stone.
Now I can finaly quit pointing out gearing commander has the same error as our speedometer.
.. I even copied and saved it in case this post/thread gets deleted.
ozart is offline
post #8 of 17 Old 03-04-2012, 09:30 PM
I hadn't seen anything about the Gearing Commander figures before that I remember. The first thing I noticed were its figures were based on the stock instruments.
post #9 of 17 Old 03-04-2012, 09:50 PM
ozart's Avatar
I've made numerous unacknowleged posts about it over the years, pretty much anytime gearing commander was mentioned.
You are the only other one that's mentioned it .... and only just now that I know of.
ozart is offline
post #10 of 17 Old 03-04-2012, 10:03 PM
I may very well never mentioned it before. It doesn't seem very important.
