(https://www.stromtrooper.com/forumindex.php)
- DL650A - 2012-2016
(https://www.stromtrooper.com/dl650a-2012-2016/)
- - 2012 WEE Strom 650 Alternator output
(https://www.stromtrooper.com/dl650a-2012-2016/71763-2012-wee-strom-650-alternator-output.html)
Does anyone know if the 2012 GleeStrom has a higher alternator output than previous models? Still 400 watts max?
Still [email protected]
400w seems monstrous after the 238w on my KLR.
Had I paid attention to this when shopping for bikes I would not have bought the Wee. |
Arne,
Would you mind posting how you add another alternator? I am really curious. I have a full set of Gerbings gear that can pull 165 watts. Actually head to Fort Eustis, VA tomorrow morning and temps at home are expected to be around 19 degrees. It is about 285 miles and 5 hours so it will be interesting. I bought a spare battery (lithium) in case I drain the battery from pulling too much with the heated gear. The trip is for work and can't risk a dead battery and no way to get going. I wonder why Suzuki would keep an alternator with such low power output on the V-Strom. |
Heated gear wattage use.....
I own a 2004 DL650 V-Strom and just went for a test ride with Gerbings Micro-Wire Jacket, Pants, Gloves, and Socks.
I have an Eastern Beaver kit that allows me to turn off one of the headlights. I have an LED tail light installed. With the dual controller set to a point where both channels are lit and "on" about 75% of the time, I had zero electrical issues. I don't think the Wee will give you trouble if you use a temp controller that allows you to cycle the heat, and you shut one headlight off. Cheers. |
I suggest an active voltage readout if running high current acessories.
some good tips here
Calculating Excess Electrical Capacity - Learning Center - Powerlet Products definitely changing to LED lights will make a difference. i usually get my jeep alternators rewound for about 30% increase but never though about a bike. I may look into it though. |
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Pro) -
