Bias Ply or Rafial Tires - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 11 Old 10-18-2019, 05:38 AM Thread Starter
Hello V-Strom owners V-Strom, going to go with the 705 Shinko tires. My question is which type bias ply or radial tire? I read pros and cons on both tires, one of the biggest difference is the price I did notice the Bias ply tire is $40 cheaper than the radial tire. My current tire has 14K, with plenty of tread, but the problem is the cupping on the tire causing uneven ride and causing the tire to heat up fast. One other issue I been having that caused the cupping is holding tire pressure, I check the pressure monthly, notice that I would lose about 8 lbs pressure per month. The tire pressure never drop below 32 psi and I keep both the front and back at 40 psi. Thoughts??? Thanks is advance for the help.
Knipper64 is offline
post #2 of 11 Old 10-18-2019, 05:43 AM Thread Starter
How do you edit post? I accidentally cut some information out at the front of the post, meant to Say, Going to replace the tires on my V-Strom with the 705 Shinko tires.
post #3 of 11 Old 10-18-2019, 07:02 AM
PerazziMx14's Avatar
I'll take Donatello tires over Rafial tires any day
When it comes to Radial verses Bias its up to you. No mater what 705 front you buy it will cup. Loosing pressure could possible be the valve core/stem slowly leaking. But it still not uncommon for a tire to loose some pressure over time. That is why we should check them on a regular basis.
Webfors likes this.
PerazziMx14 is online now
post #4 of 11 Old 10-18-2019, 10:34 AM
Not to disagree, but the front 705's on my Wee don't cup. Over 8K miles on them now and the tread pattern looks like new.. Typically run 36 front and 40 rear.
sngltrk and V-Harry like this.
post #5 of 11 Old 10-18-2019, 12:17 PM
Webfors's Avatar
Who's Rafial?
I'm running Shinko 804/805's bias knobbies right now, which is a surprisingly good tire.
Are you saying the 705 comes in bias or radial? If so, buy the radial.
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #6 of 11 Old 10-18-2019, 12:34 PM
Yes the front Shinko 705 comes in bias or radial. Bias ply tires do have their place in motorcycling don't automatically think they are infertior to radial.
Every front Shinko 705 I've seen with more then 4,000 miles had cupping and only got more pronounced as the mileage went up.
I run them at 36/38 front and 40/42 rear
Here's a good read on bias versus radial tire construction from Revzilla so you can help formulate your own opinion of what is best for you:
https://www.revzilla.com/common-trea...-radial-tires:
post #7 of 11 Old 10-18-2019, 12:42 PM
V-Tom's Avatar
Can't speak about the brand of tires or radial vs bias.
I do want to say that if your pressure drops steadily 30 psi and then doesn't drop after that you probably have a small nail or similar in the tire. Higher pressure expands the hole and causes the leak. When the pressure drops the hole seals itself and stops or slows down the leaking.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #8 of 11 Old 10-18-2019, 09:35 PM Thread Starter
Bias Ply or Radial Tires
What is another good off road tire for the week beside shinko?
post #9 of 11 Old 10-18-2019, 10:08 PM
Brockie's Avatar
Mitas E-07. A 50/50 tyre that is competent on seal and excellent on dirt/gravel. Much better that the OEM Bridgestone's IMO.
kd70qc likes this.
Brockie is offline
post #10 of 11 Old 10-18-2019, 10:51 PM
kd70qc's Avatar
+1 on the Mitas E-07’s. I’m on my third rear and second front. They are good on road, and good on gravel/dirt fire roads. They are a little buzzy, but -for me- they remove the “riding on ball bearings” feeling I got with the OEM tires when I went off road (even at reduced pressure.) I haven’t had any problems with ridability at any posted speed limit, but my first front would start to wobble at 93 mph (while passing). It was a Dakar. My current front is a standard E-07 and doesn’t have that problem. They have respectable tread life too.
Brockie likes this.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
