Rattling sound from rear - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By bajakirch
post #1 of 8 Old 09-08-2019, 05:06 PM Thread Starter
bajakirch's Avatar
I've lately noticed what sounds like a rattling or chattering sound that seems to come from the rear of my '12 650. It seems to occur as I'm releasing the clutch and power picks up to the rear tire. It's been hard to isolate what or where it's coming from, because I can't seem to replicate it while the bike's on the center-stand.
Things I've been thinking it could be include the dreaded clutch-rattle, a too-loose chain, or maybe even just my Givi top box vibrating.
What are some ways I might be able to diagnose what I'm hearing?
bajakirch is offline
post #2 of 8 Old 09-08-2019, 07:25 PM
No dreaded clutch rattle in the 650's "that's a 1000 thing", I would take off the top case and check all fasteners first and foremost. Are you sure the cush rubbers are also in good shape, how about chain/sprockets?
post #3 of 8 Old 09-09-2019, 02:04 AM
StuckOnEarth's Avatar
I had the same thing. Check the rear axle adjustment bolts on the back of the swingarm. They can loosen up a bit -- if they're loose, snug them up.
StuckOnEarth is offline
post #4 of 8 Old 09-09-2019, 11:46 AM
blaustrom's Avatar
How many miles?
Worn cush rubber dampers and/ or worn sprocket carrier baring.
I assume nobody has messed with the counter sprocket for quite a while so no chance that nut is not tight?
Worn out chain?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 8 Old 09-09-2019, 05:56 PM Thread Starter
bajakirch's Avatar
The bike has just shy of 35,000 miles; I got it with 19,600 and am still running the same chain. So, yeah, that's currently my leading suspect. My plan has been to run the bike as is through the remainder of the season, then do a chain/sprockets replacement over the winter.
post #6 of 8 Old 09-09-2019, 06:00 PM
oldjeep's Avatar
Check that the rubber pieces that keep the chain from slapping the swing arm directly are still there too.
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
post #7 of 8 Old 09-09-2019, 06:00 PM
blaustrom's Avatar
Well if the chain is real bad (a big IF) it can destroy your case. Pull at the chain at the rear sprocket at the 3 o'clock position. If can see through it replace the chain. Better 200 bucks now than a lot more later.
Blau2 2014 DL1000A
post #8 of 8 Old 09-17-2019, 09:56 PM Thread Starter
bajakirch's Avatar
I spent some time working on the bike today. After giving the chain a well-needed cleaning and adjustment, I took it for a test-ride and the chattering sound is gone.
Certainly the chain was showing signs of its age, and the front sprocket had the beginnings of some hooking. So if there was any doubt about swapping the chain and sprockets this winter, there isn't any more.
Big B likes this.
