Hard tires? I was told my tires are "too hard". - Page 6 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 103Likes
post #51 of 83 Old 09-11-2019, 01:15 PM
NeTexasDude's Avatar
Here is my 2 cents. I am a tightwad when it comes to tires on anything... I use them up... All of them. Now with this said I am VERY cautious on my VStrom but I ride them all the way down and the last two rear tires ran them to the belts...
I live in Texas and out chip-seal asphalt roads when over 100 degrees KILLS TIRES. Winter is when I put in my new tires. I ride most of winter and this is when I can't afford slippage.
Back to summer, if I were you I would inspect with a flashlight and really stress the tire for visible cracks. Then if it passes that test. Move on to a ride, do a high speed emergency stop, do some u-turns in parking lots and power take off.. if the tires slip, we'll go do some BURNOUTS and have some teenager fun in a parking lot or your driveway.. safety is our number one concern over saving a buck.
I buy two rear tires a year most of the time and I run Shinko because of price and YES I've tried several other TOP name brands and they all wear out in Texas heat so I buy clearance tires and so thankful VStrom uses common sizes. Heck my latest fire I just bought last month was a Shinko 712r for 72.00... deal deal deal.
So point is inspect and use em up if they pass your inspection.
File Type: jpg 15682184738738124800134070640365_1568218491928.jpg (229.7 KB, 3 views)
She-Strom likes this.
NeTexasDude is offline
post #52 of 83 Old 09-11-2019, 01:32 PM
OydnaR's Avatar
old tires are good for burnouts, don't take long to get rid of the tread
stop before you explode the tire and flail the steel belts into your tail (I learned by observation, not doing)
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #53 of 83 Old 09-11-2019, 10:03 PM
shu
shu's Avatar
???? Cautious = running on tires with the belt exposed????
I saw a tire with metal threads exposed recently. It was sitting in the local shop waiting to be replaced.
I asked the shop owner, who sells a lot of tires, if he would ever ride on a tire like that. His reply: I wouldn't ride that one from the parking lot into the shop.
................shu
shu is offline
post #54 of 83 Old 09-11-2019, 11:35 PM
Regarding the opinion that Trail Wings should be replaced just because they "are"- Is there some evidence to show they are somehow dangerous tires and are hazardous to the rider, or is this just bullshizzle? My 2017 came with them and I've felt completely safe riding in the twisties of southeastern Ohio, albeit on pavement. They are wearing evenly and roll out smoothly, and I've only had a couple of noticeable traction control incidents, which were in turns with some debris on the road. They do fine in the rain, and appear to hold air. The only real negative I've found in forums was that they don't track well on gravel roads. I don't do much of that. Send me all of your new discards, I'll use them. Unless, of course, they are truly unsafe at any speed. Best, DD
Dubldee17 is online now
post #55 of 83 Old 09-12-2019, 01:02 AM
I remember posting a photo in some thread here of a friend of a friend in Hungary who rode his old Gold Wing from the Croatian coast to central Hungary at average speeds of 135 kph with a palm-sized chunk of rubber completely missing, down to the cords! A huge delamination. I saw the tire in person, it was crazy. Just to say, some people will take crazy chances.
Correction. The photo was of the tire, not the friend.
06 V-Strom DL650
John V Strom, Jr. is offline
post #56 of 83 Old 09-12-2019, 07:25 AM
PerazziMx14's Avatar
As it was pointed out to me via PM unless you do not work directly in the tire industry no matter your personal experience, your thoughts, opinions and even real world experiences are merely anecdotal and are not be taken into consideration when evaluating used tires or new tires that have been in storage.
So I'll re-ask the OP's question to only the certified tireolgists; Is a 6 year old tire safe to continue to keep in service?
Dubldee17 likes this.
PerazziMx14 is offline
post #57 of 83 Old 09-12-2019, 07:50 AM
madscrapper85's Avatar
There is no definitive answer for that question. Can it be ridden if it good shape I'm sure you can ride it, is it safe and that fine sir is the real question is completely unknown per each situation. Is a 6yr tire as grippy or as malleable or is it too malleable? Is your life worth the risk is your health worth $300 set of tires. That's for each and everyone to ask themselves. Manufactures won't stand by it at that age so why should I?
Big B likes this.
madscrapper85 is online now
post #58 of 83 Old 09-12-2019, 08:43 AM
Big Boy's Avatar
Something to consider:
If the tire was designed as a "sport" tire with soft/sticky tread rubber compounds, the aging/hardening process will not affect it as severely for 'regular' styles of riding. Whereas the 'high mileage' harder tire compounds will increase in hardness beyond safe riding standards over the same time period.
W. C. Fields
Big Boy is offline
post #59 of 83 Old 09-12-2019, 09:58 AM
Unless there is a privacy agreement or some trade protected information would it be possible to list the tire manufacturer you work for and what type tires you produce?
post #60 of 83 Old 09-12-2019, 10:32 AM
BCSTROM's Avatar
What about oil?
BCSTROM is offline
