Air Filter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 23 Old 08-27-2019, 09:18 PM Thread Starter
Air Filter
It's time for a new one 16' dl650. OEM, K&N or other, what you guys using?
2016 DL650
ronc is offline
post #2 of 23 Old 08-27-2019, 09:45 PM
branthopolis's Avatar
If you ride offroad....at all.. I would personally recommend sticking with the OEM filter. For strictly road use, you'll probably be OK with whatever...until you aren't.. or something like that..
Gert, STCorndog and outdoorgb like this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #3 of 23 Old 08-27-2019, 11:10 PM
blaustrom's Avatar
OEM. Put it in and forget it for the next xxxxxx miles. It's not really easily accessible
RLBranson likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 23 Old 08-27-2019, 11:32 PM
I also need to change my air filter, is the oem filter that much better?
Cutters is offline
post #5 of 23 Old 08-27-2019, 11:36 PM
"Out of curiosity, why do you say this?"
Maybe he is like me and gives it a blast of compressed air every season or two. i put a bit of window screen over the inlet and haven't had the bug and debris collection that I had when I got the bike.
i change the air filter in my 4Runner when the mice eat a hole in it. Some things like air and oil filters work better when they have a bit of use.
Gert likes this.
notacop is online now
post #6 of 23 Old 08-28-2019, 09:10 AM
K&N, BMC, and any other oiled gauze filters might give slightly better airflow as long as they aren't over-oiled so theoretically they could produce marginally more horsepower on a stock motor. The real advantage is that they can be cleaned, reoiled, and reused which could save you money in the long run. BUT. If you ride anywhere with significant fine dust or silt in the air you are probably better served with the OEM filter.
IMHO and YMMV should probably be applied to this answer...
RidgeRunner729 and RLBranson like this.
~Mark
2015 DL1000A
2005 YZ250
post #7 of 23 Old 08-28-2019, 09:28 AM
Personally, I would just go with the OEM and be done with it. It's not something that's done very often, so if there's any cost difference, it's not much when you spread it out over time. Some folks like the oiled filters such as KN. Those are fine too if that's your thing, but it just adds time to the process because they have to be cleaned, allowed to dry, then oiled again.
Houstrom46* is offline
post #8 of 23 Old 08-28-2019, 10:38 AM
Lrobby99's Avatar
The air filter I try and avoid is the OverthinkingIt Air Filter.
Lrobby99 is offline
post #9 of 23 Old 08-28-2019, 11:29 AM
I would get the OverthinkingIt Air Filter only if I was using OverthinkingIt Oil.
To tell you the truth, I really haven't thought about it all that much...
Big B, Houstrom46* and RLBranson like this.
gdrew is offline
post #10 of 23 Old 08-28-2019, 12:58 PM Thread Starter
Also looking to replace my front pads with EBC.
FA229HH = Left
FA231HH = R
Is this correct?
2016 DL650
ronc is offline
