Clutch side screw length?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 08-24-2019, 08:36 PM Thread Starter
shauneal's Avatar
I’ve dropped my 2013 VStrom this summer a couple times doing terrific off road trips to WV, so I recently purchased new hand guards and clutch assembly, all OEM parts, but every screw it comes with is super short and doesn’t fit with the weight part and other parts. Am I missing something here? Where do I get another long screw? I tried with nothing on the clutch side handlebar and it was still too short??
shauneal is offline
post #2 of 11 Old 08-24-2019, 08:46 PM Thread Starter
shauneal's Avatar
Left one is current setup, middle screw by itself is what came with new clutch assembly unit, far right is the brake side unit I believe that I ordered incorrectly.
File Type: jpg C78D1751-8138-4D49-BE32-29FDA0E383E3_1566690326189.jpg (424.5 KB, 6 views)
shauneal is offline
post #3 of 11 Old 08-25-2019, 10:17 AM Thread Starter
shauneal's Avatar
Perhaps I solved my own dilemma, once I got all the pieces out of the handlebar, it appears the “needed” pieces are less than what was there before. Really strange. Does anyone else have a super long handle bar screw? Maybe it was a custom job by previous owner?
shauneal is offline
post #4 of 11 Old 08-25-2019, 08:30 PM
Brockie's Avatar
Below is the standard setup. It seems the same as the right side of your image.
On the left you seem to have a helmet hook. Is that the reason for needing a longer bolt, and a PO could only find a MUCH longer one?
Brockie is offline
post #5 of 11 Old 08-25-2019, 09:31 PM Thread Starter
shauneal's Avatar
where did your oem image come from? None of the images on the suzukiparthouse for a 2013 Vstrom 650 show that long bolt with the piece for the handle cover....The long screw in my picture was “not” sent with the new kit from Suzuki....does anyone know where to get the long screws? That image you attached is the right bolt ; )
shauneal is offline
post #6 of 11 Old 08-25-2019, 11:07 PM Thread Starter
shauneal's Avatar
And yes I do use a helmet hook on the clutch side handle, but the screw on the brake side/throttle handle is also too short. So strange. The bike had two original long 140mm M6 bolts just like the picture you sent, and now I don’t see them as an option. I’ll call Suzuki tomorrow as well. Appreciate the help
shauneal is offline
post #7 of 11 Old 08-26-2019, 12:30 AM
Hilo Haole's Avatar
I was looking at Suzuki parts house and Babbits online, both the same outfit. The long screw is shown in the Handlebar fiche. The shorter screw is shown in the Knuckle cover fiche which were optional.
Paul
2005 DL 1000
2008 ST 1300
Hilo Haole is offline
post #8 of 11 Old 08-26-2019, 01:18 AM
The longer bolt allows for the spacer when installing factory plastic handguards. The space I refer to is shown in your pic on the left above the bar end weight.
Sp56
Southpaw56 is offline
post #9 of 11 Old 08-26-2019, 05:08 AM Thread Starter
shauneal's Avatar
Brockie - Where did you get this image? This image is different than everything they show on Babbitt’s - which year, bike and part shows the attached?
File Type: png 3206B9A5-FDAB-4084-9913-56D7EE8E8B70_1566806925420.png (150.0 KB, 2 views)
shauneal is offline
post #10 of 11 Old 08-26-2019, 05:10 AM Thread Starter
shauneal's Avatar
. Sorry, still learning how to reply to a specific post - Brockie, where did you get this image? Your image (which I am attaching again) is different than anything they show on Babbitt’s currently?
File Type: png 520F8C20-118A-4ADE-8E60-32BC17F2C658_1566807024576.png (150.0 KB, 3 views)
shauneal is offline
