Chain condition - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #1 of 32 Old 08-06-2019, 07:01 PM Thread Starter
Chain condition
2013 650A with 19,000 miles. I can see no wear on sprockets and can't pull chain away from rear sprocket. My concern is some links are stiff when cold. They can be straightened easily by hand and are not as stiff after riding. The chain stretch test is at the limit at several runs of chain.
This may be the original chain-there is no master link.
Should I be concerned?
Ron
Belton Tx
2013 650
MPRblue is offline
post #2 of 32 Old 08-06-2019, 07:13 PM
branthopolis's Avatar
If it gives you piece of mind, install a new chain & sprockets... 19,000 is a reasonable replacement interval. Many have gone longer, but everyone's situation is different.
Big B, chicago and Motor7 like this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #3 of 32 Old 08-06-2019, 07:31 PM
locoblanco's Avatar
It's probably not "bad", but at the limit of the spec makes it fair game for replacement.
Personally, I go for the pull away from the rear sprocket test over the 21 pin/ 319mm, (or whatever it is), as I find that a difficult measurement to do accurately, but if you are confident in your measurement it's better to replace than have a problem.
I recommend denniskirk.com for a matched set, either RK or DID. Fair prices, good customer support.
locoblanco is offline
post #4 of 32 Old 08-06-2019, 08:31 PM Thread Starter
I'm not real confident on stretch measurement. It is hard to keep tape centered on first pin while reading scale on second pin. Since the chain doesn't pull away from sprocket, I think it is probably good. What about stiff links?
Ron
Belton Tx
2013 650
MPRblue is offline
post #5 of 32 Old 08-06-2019, 08:49 PM
locoblanco's Avatar
If you can move them by hand they are not frozen. A good cleaning with kerosene may loosen them up more. Make sure the o rings are undamaged.
post #6 of 32 Old 08-06-2019, 09:26 PM Thread Starter
The O rings look good, but a small amount of grease is being flung out.
Ron
Belton Tx
2013 650
MPRblue is offline
post #7 of 32 Old 08-06-2019, 10:08 PM
V-Tom's Avatar
Don't clean the chain! (With kerosene or anything else)
Get some transmission fluid and put a drop on where the plates touch each other. That should loosen up the links. Then use some good oil-based lube and carefully lube each link. (I like Wurth HHS2000 as my lube.) Once you have this chain working fine you lube it with every fill-up and after every ride in the rain. (This will take about 10 to 20 seconds if you have a centerstand ) Don't clean it, people's advice to do so is just repeating what others have said on the web.
I now have my chains comfortably lasting 50, 000 miles / 80,000 km.
..Tom
Big B, om28, notacop and 1 others like this.
SMIDSY detailed report.
V-Tom is offline
post #8 of 32 Old 08-06-2019, 10:32 PM
kd70qc's Avatar
If the “small amount of grease” being slung out looks like tiny black spider webbing, get a chain and sprockets set on order. If you are a daily rider, by the time it gets here you will want to replace it.
BTW when I gently cleaned my chain with kerosene and a tooth brush, several of my o rings (or x-rings or whatever) failed a few weeks later. My chain already had over 20k and I was asking questions like you are.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #9 of 32 Old 08-07-2019, 06:34 AM Thread Starter
..Tom
I looked at the Wurth site and the closest thing they list is HHS-K hinge lubricant. Is this an update to HHS2000?
Ron
Belton Tx
2013 650
MPRblue is offline
post #10 of 32 Old 08-07-2019, 06:47 AM Thread Starter
..Tom
Ron
Belton Tx
2013 650
MPRblue is offline
