Chain condition - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #11 of 32 Old 08-07-2019, 10:10 AM
V-Tom's Avatar
Originally Posted by MPRblue View Post
I looked at the Wurth site and the closest thing they list is HHS-K hinge lubricant. Is this an update to HHS2000?
Yes it was re-labled in the USA but same stuff.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #12 of 32 Old 08-07-2019, 10:36 AM
Your 50K mile chain life is like double what others consider good. I have WD40 in the gallon can that I used to clean the chain with a grunge brush.
A well oiled chain with the right lube won't need cleaning per se, perhaps a wipe down?
Oh, getting a good sprocket set and a quality chain helps with chain life. Look to the Vendors here on the forum first.
When I changed the front sprocket for a 16 tooth it was solid steel and I haven't noticed a change in noise or operation, it did drop the cruising rpm 500.
notacop is online now
post #13 of 32 Old 08-07-2019, 11:35 AM
Big Boy's Avatar
Originally Posted by V-Tom View Post
Don't clean the chain! (With kerosene or anything else)
Get some transmission fluid and put a drop on where the plates touch each other. That should loosen up the links. Then use some good oil-based lube and carefully lube each link. (I like Wurth HHS2000 as my lube.) Once you have this chain working fine you lube it with every fill-up and after every ride in the rain. (This will take about 10 to 20 seconds if you have a center stand) Don't clean it, people's advice to do so is just repeating what others have said on the web.
I now have my chains comfortably lasting 50, 000 miles / 80,000 km.
..Tom
Very good advice!!!!!!!!!!!!! I second V-Tom's recommendations. Follow them to the letter and you too will have a chain that lasts that long.
My Experience: I cleaned a chain with kerosene years ago on a different bike. The chain failed very quickly after that "cleaning". I DON'T USE ANY SOLVENTS TO CLEAN MY CHAIN. The chain on the ZRX1200 had over 36,000 miles when I sold it. It was still going strong.
W. C. Fields
Big Boy is online now
post #14 of 32 Old 08-07-2019, 12:13 PM
don't wait for the chain to get kinky. keep it lubed with ATF to keep the O rings from becoming stiff and cracked.
It is not the kerosene or WD40 that kills the chain when cleaning it but the brushing that damages the O ring seal . Don't brush O rings, especially in a dirty environment.
Gert and brutalguyracing like this.
RLBranson is offline
post #15 of 32 Old 08-07-2019, 12:34 PM
V-Tom's Avatar
I literally never clean my chain, never wipe it down and don't see any reason to. Any dirt on it is superficial. I suppose there would be little harm in gently wiping off the chain (as long as dirt isn't getting pushed into the O-Ring area) but I can't see any reason to do so and I don't do it.
I don't know if it is available in the USA but in Canada there is a factory kit that provides an OEM chain and OEM front and rear sprockets. It is a decent deal and I have been using it. My front sprockets are replaced before the chain and rear so I get a generic steel front sprocket for the in-between change. If it wasn't available I would just get a quality chain set like DID.
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #16 of 32 Old 08-07-2019, 09:01 PM
Big Boy's Avatar
ANY SOLVENT can and will remove the lubricant behind the O Rings. The chain will then fail. Brushing the chain only speeds that process.
W. C. Fields
post #17 of 32 Old 08-09-2019, 02:49 PM Thread Starter
I ordered Wurth HH-K lube and sprayed it on and found it to be clean and odorless. I then noticed that the can was labeled HHS plus. I called the distributor and was told that the HHS plus was the latest version of HHS-K.
We shall see how it works.
V-Tom likes this.
Ron
Belton Tx
2013 650
MPRblue is offline
post #18 of 32 Old 08-09-2019, 03:07 PM
Shouldn't the o-rings prevent the solvent from getting inside the link? Within reason, of course - some solvents are very thin and "wicking". But pretty much every spray chain lube is carried in a volatile solvent, even the o-ring safe ones.
ps This is not a problem I have with my R1200RT
V-Strom Ry 2 is online now
post #19 of 32 Old 08-09-2019, 03:29 PM
O rings in good condition form a tight seal to keep mild solvent out and the internal lube inside. mild solvent is used to flush automatic transmissions so you know that mild solvent is not is not harming the many O rings and neoprene seals in the expensive auto transmission. Mild solvent or kerosene should not be applied to an O ring chain with a stiff brush. you should use only a very soft brush or dauber to apply mild solvent or kerosene to clean an O ring chain and it is not needed very often or not at all if the chain does not get very very dirty.
ATF will keep the O rings pliable so that they can do their job of sealing dirt out and lubricant inside the chain.
post #20 of 32 Old 08-09-2019, 06:02 PM
V-Tom's Avatar
Here is how my chain looks right now:
This is typically how my chain looks and where it lives. Literally never "cleaned" or even wiped down. I am on some unpaved roads though the course of the week so the sand and dirt is normal. It was lubed last night on the way home so would have about 100 km/ 60 miles on the lube. It will be lubed again tomorrow night as I wil lfill up the tank again.
This is the third chain on my DL1000. The bike has a bit over 191,900 km / 119,250 miles. The chain has about 28,500 km / 17,750 miles so should be good for about 52,000+ km / 32,000+ miles before I replace it.
..Tom
Motor7 and brutalguyracing like this.
My Opinion:
My Stroms:
V-Tom is online now
