Please excuse the rookie question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 21Likes
post #1 of 24 Old 07-27-2019, 12:05 PM Thread Starter
Rtuleja's Avatar
Hey folks,
Very new strom owner here. My '12 is bone stock with about 4k miles on it and I'm thinking I'd like to swap the tires out.
Now for the stupid question- how do I get this bike off the ground? I have a motorcycle jack that I use for my sportster, but it doesn't look like I can use that without maybe hurting some things and I dont have a center stand.
Rtuleja is offline
post #2 of 24 Old 07-27-2019, 12:21 PM
nvr2old's Avatar
Center stand is what I use for the rear. Center stand and a floor jack for the front.
Spools and a lift stand is probably best without a center stand. Some are known to lift it from the ceiling with ropes and pulleys.
notacop and eff like this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 24 Old 07-27-2019, 12:24 PM
nvr2old's Avatar
The stand used on the Sportster might be used if you took a piece of plywood w/ shims under the motor.
tjosephtoo likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
post #4 of 24 Old 07-27-2019, 09:16 PM
chicago's Avatar
tire changing is definitely a lot easier with a center stand on these bikes.
notacop, a572mike and bnolsen like this.
14 tooth for me
chicago is offline
post #5 of 24 Old 08-11-2019, 10:14 PM
I invested in the pit bull. It is rock solid for a rear lift especially when paired with a wheel chock up front. Easy to use and can be adapted to other bikes.
Big B and Gert like this.
current ride
'16 DL650
previous rides:
'09 Buell Ulysses
'05 HD Dyna SuperGlide Custom
'08 Suzuki Bandit 1250ABS
'01 HD ElectraGlide Std
'90 HD ElectraGlide Sport
'80 HD WideGlide
'80 Suzuki GS850L
406RIDER is offline
post #6 of 24 Old 08-11-2019, 11:25 PM
Life is so much more simple if you invest in a center stand.
Big B, Gert, Boriqua and 1 others like this.
post #7 of 24 Old 08-11-2019, 11:43 PM
I have had a number of bikes that did not have a center stand. what I have done involves either 2 automotive jackstands or 2 sturdy milkcrates. with the bike on the side stand put a jackstand or milk crate under the opposite side of the bike. under the frame or non folding part of the foot peg. with the other jackstand or milk crate near the side stand lift the side stand side of the bike up with the handlebars. with your foot slide the jackstand or milkcrate under the frame or the nonfolding part of the foot peg. you may need to use a couple pieces of wood to get enough height. loosen the axle nut before raising the bike so that you don't shake things while it is off the ground. after you have got the rear tire off and back on then use an automotive jack and a piece if wood under the engine or skid plate to raise the front wheel off the ground. Again loosen the axle before raising the bike.
You may be a red neck if one of your most prized possessions is a matched set of milk crates.
notacop and tsrDave911 like this.
RLBranson is offline
post #8 of 24 Old 08-11-2019, 11:58 PM
Brockie's Avatar
A main stand just makes everything so much easier and stable - especially when removing wheels, and it goes with you wherever you go. Its weight is low down, so why not?
Brockie is offline
post #9 of 24 Old 08-12-2019, 12:09 AM
BC Rider's Avatar
Just ahead of the rear axle are two threaded bosses that will take stand spools. They are cheap on Amazon or Ebay. Then get a race stand. I have a 50 dollar Princess Auto(Harbor Freight) one that works very well. I put an ATV lift under my bash plate to work on the front end. Leave some load on the race stand and it is very stable. With out a bash plate you could use some wood blocks to shim under the engine but should strap the bike to the lift.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #10 of 24 Old 08-12-2019, 05:53 AM
PerazziMx14's Avatar
What motorcycle jack do you have?
PerazziMx14 is offline
