Red or White LED for Brake/Tail - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By SoInStrom
  • 1 Post By blaustrom
post #1 of 7 Old 07-27-2019, 11:50 AM Thread Starter
What is the guideline for LED color when replacing bulbs? White or red within the brake/tail light enclosure? Brighter with white or washed out red with white? Is it just personal preference? Anyone have pics showing both?
Thanks
2012 DL650 Adventure
SoInStrom is offline
post #2 of 7 Old 07-27-2019, 12:22 PM Thread Starter
After some research, what I have found is the rule of thumb is to match the LED color to the lens color if possible.
Spec likes this.
post #3 of 7 Old 07-27-2019, 01:05 PM
so if you have a clear taillight lense use a white LED
RLBranson is online now
post #4 of 7 Old 07-27-2019, 01:06 PM
Use a red LED. If you use white, your taillight will look pink.
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #5 of 7 Old 07-27-2019, 04:15 PM
blaustrom's Avatar
You must use a red LED for the tail light. The white LED has a very different spectrum that does not mach much of the red light housing spectrum. Means not much of the white LED light comes out and its not pure red either.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 7 Old 07-27-2019, 06:52 PM
Why is it a white incandescent bulb work well in a red plastic brake display but not a white LED? Seems the red would get lost in the spectrum of the lens and maybe not show at all?
https://pinside.com/pinball/forum/to...nd-lens-colors
Maybe there is truth in color matching?
post #7 of 7 Old 07-27-2019, 07:47 PM
blaustrom's Avatar
Incandescent light is rather similar to sunlight in that it has a complete and wide spectrum. LED's don't. They have a tight and rugged spectrum. See the cool white (5000-6000K type LED) has little red vs the incandescent that has a lot.
The red brake light lens filters out most wavelength's but let only the red pass, hence incandescent white bulbs work fine whereas cool white LED's have little light energy in the red wavelength:
thirdofthree likes this.
Blau2 2014 DL1000A
