Headlights out - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 21 Old 07-26-2019, 02:49 PM Thread Starter
Headlights out
I changed the original battery out and before start I noticed that the high bean indicator was lit and the dimmer switch had no effect. The headlights were not on prior to start and after start still dont work.
The idle was a little high, but settled down after a few seconds.
Any ideas?
Ron
Belton Tx
2013 650
MPRblue is offline
post #2 of 21 Old 07-26-2019, 03:12 PM
check fuses and connections first
Plateauplower is offline
post #3 of 21 Old 07-26-2019, 03:31 PM Thread Starter
Fuses good and only connections I took loose were the battery cables and two extra wires on terminals for charger pigtail and horn relay(aftermarket).
Ron
Belton Tx
2013 650
MPRblue is offline
post #4 of 21 Old 07-26-2019, 03:39 PM Thread Starter
When I move headlight switch through it's positions, the blue high beam indicator flickers slightly.
Ron
Belton Tx
2013 650
MPRblue is offline
post #5 of 21 Old 07-26-2019, 03:48 PM
I would remove and reinstall the cables you removed, ensure you have good connections if the fuses are good. It sounds like its shorting out which ground is generally the first thing I look at with 12v electrical gremlins.
Motorpsychology likes this.
post #6 of 21 Old 07-26-2019, 04:19 PM Thread Starter
Cables all connected securely. I think the slight flicker of hi beam indicator is probably normal and shows that the switch is working.
My first thought was headlight relay but apparently there is not one.
Ron
Belton Tx
2013 650
MPRblue is offline
post #7 of 21 Old 07-26-2019, 05:31 PM
What kind of voltage are you getting at idle. Does the passing switch get any light. Hopefully someone will chime in that might have a better idea.
post #8 of 21 Old 07-26-2019, 05:38 PM Thread Starter
14.5 at idle,[email protected] Passing switch gives no light.
Ron
Belton Tx
2013 650
MPRblue is offline
post #9 of 21 Old 07-26-2019, 06:51 PM
BC Rider's Avatar
If all was good before the battery change then during the change is most likely where the problem arose from. Bad ground or bad hot to the lights. One set of extra wires reversed. Does your horn work. Sounds like it is a new bike to you. Check to make sure there isn't some sort of light relay spliced in somewhere. A common lighting problem is in the starter switch where it cuts the headlights as it juices the starter relay. The contacts get burnt.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #10 of 21 Old 07-26-2019, 07:16 PM Thread Starter
Horn works. I took left side switch housing apart and see no burn marks and contacts are clean. I sprayed DEOXIT in starter switch and then disconnected the extra battery wires with no effect. I just noticed that my odometer gained about 11,000 miles during the troubleshooting!
Ron
Belton Tx
2013 650
MPRblue is offline
