Saddlebag mounts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-23-2019, 06:18 PM Thread Starter
Saddlebag mounts
Could someone post some photos of OEM Suzuki saddlebag mounts that fit my 13 650? I think the ones on my bike may be OEM, but they have cheap cases on them that are not secure.
Ron
Belton Tx
2013 650
MPRblue is offline
post #2 of 11 Old 07-23-2019, 07:14 PM
PerazziMx14's Avatar
Might be faster if you post pictures of your panniers and racks?
PerazziMx14 is offline
post #3 of 11 Old 07-23-2019, 11:01 PM
bendmac's Avatar
These are the factory mount and left-side pannier from my 2013 Wee. (The tool tube is something I fabbed up...)
Bendmac/Central Oregon
2013 Wee Adv...
EnduroGuardian bash plate/highway pegs/radiator guard;
AdventureTech LLC peg lowering mounts/mirror extenders/fork brace/shifter relocation kit, 2" extended front brake line;
Saddleman Gel-Channel Tech seat;
Barkbuster Storm hand guards;
Oxford heated grips;
Blue Seas 5025 6 circuit fuse block;
12v weatherproof power port;
Eastern Beaver headlight relay kit;
Cree LED lights;
Signal Dynamics voltage monitor;
Kisan signalMinder
PWD Stebel horn kit;
"Home grown" tool tube;
"Sasquatched" (Adventure Power Sports) rear shock
Madstad bracket and 22" screen
Roadstercycle SH775 R/R upgrade
SW-Motech bar risers
Mr. Ed's Moto custom seat
Superbright LED headlight bulbs and other bulbs converted to LED
bendmac is offline
post #4 of 11 Old 07-24-2019, 06:43 AM Thread Starter
Thanks. Mine are not like that. If I could figure what bags are made for mine, I would buy some. The "bags" that are on now are Seahorse cases that are held on by bolts and clips. No matter how much I tighten the bolts, the cases move on the mounts. Until I can make a change I have ratchet straps around the cases.
Ron
Belton Tx
2013 650
MPRblue is offline
post #5 of 11 Old 07-24-2019, 11:19 AM
bendmac's Avatar
If you post up some pics of what you have on there now, I'll bet one of the inmates in here can give you some adfitional info...
bendmac is offline
post #6 of 11 Old 07-24-2019, 08:34 PM Thread Starter
Here are the photos. The saddlebag mount has 2 threaded holes on the bottom bar. I am thinking this is a mount for a specific saddlebag.
The second picture shows the back of the Seahorse case. The bottom 2 clips fit snugly on the bottom bar, but top two have a clearance between the spacer and the top bar. My concern is that if the top clips rotate then the bag will fall off.
Any suggestions?
Ron
Belton Tx
2013 650
MPRblue is offline
post #7 of 11 Old 07-24-2019, 10:12 PM
Those factory mounts look stout enough. If you can live with permanent mounts just bolt the buggers in place. Anytime you have easily removable saddle bags there is a flop factor.
My Seahorse bags are bolted on the factory frames and are quite happy to crush my ankle and not move at all in a fall over.
notacop is online now
post #8 of 11 Old 07-25-2019, 04:40 AM
scotty707's Avatar
Any suggestions?
Those look like Givi racks.
I have a similar setup, complete with Seahorse cases and the Happy Trail pucks like yours in the picture. So long as you tighten the pucks sufficiently, you should have no problem with rotation. I've taken mine on some pretty rough roads and they haven't loosened at all.
2015 DL650
"I am learning ... that it is remarkably easy to do things, and much more frightening to contemplate them."
-Ted Simon
scotty707 is offline
post #9 of 11 Old 07-25-2019, 05:41 AM Thread Starter
Once tightened, do the bags move on the rack?
Ron
Belton Tx
2013 650
MPRblue is offline
post #10 of 11 Old 07-25-2019, 12:03 PM
I would take the top clips off and use the 2 holes in the middle bracket and bolt through the Seahorse. That's what i did with mine.
I bent a piece of 1" strap in an 'S' to sit on the lower rail. I found some clevis pins with several holes in them and using a clip to retain it through the upper bracket.
I bolted solid one side and experimented with the other. Both do not move a bit.
I used the clevis pin through one hole and a plastic handled bolt in the other. https://www.googleadservices.com/pag...9aACCEM&adurl=
It's been a couple years and the knob has not loosened by itself.
I used 1/4 fender washers to spread out the stress.
I can't do pics, sorry.
