Oil on left side engine mounting bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-02-2019, 08:05 PM Thread Starter
StuckOnEarth's Avatar
Over the past few days I rode nearly 200 kms on a gravel road that was washboard for nearly the entire way. On my return, I notice that there's a small bit of oil at the left side engine mounting bracket (see photo). I checked my engine oil level before leaving on this trip and it doesn't appear to have changed at all. I can't see oil anywhere on the engine behind the bracket. Bike is a 2015 dl650 exp.
Does anyone here know why there would be oil here?
Thanks.
StuckOnEarth is offline
post #2 of 6 Old 07-02-2019, 08:20 PM
locoblanco's Avatar
That bolt goes through an oil passageway. Recheck torque. May need to replace the washer.
locoblanco is offline
post #3 of 6 Old 07-02-2019, 08:24 PM
Rolex's Avatar
If you do a search on this site you will find more information.
I have seen this before, the oil leaks from the inside of the motor and travels down the engine bolt that passes through the block.
If you look at a cutaway of the motor you can see where it all happens.
I think most just learn to live with it.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 6 Old 07-02-2019, 10:32 PM
Fox
Fox's Avatar
Mine has leaked from there for a very, very long time. Previous owner put a frame slider on it, so it looks like a sewer pipe on the inside. I don't worry about it.
Fox is offline
post #5 of 6 Old 07-02-2019, 10:34 PM Thread Starter
Thanks for the info -- I checked the bolt and it doesn't appear loose at all but I think you're correct about replacing the washer -- I'll give that a try. Appreciate the info.
Not an option but thanks.
post #6 of 6 Old 07-03-2019, 08:22 AM
D.T.'s Avatar
Cases just use some black RTV sealant. May have to split the cases if you want it to stop leaking.
D.T. is offline
post #7 of 6 Old 07-03-2019, 08:13 PM
Rolex's Avatar
Post #50 will show you what you are dealing with, there should be no oil in the bolt area, but you are far from the first.
https://www.stromtrooper.com/dl650-d...il-leak-5.html
2014 V2, Snoopy
Rolex is offline
