Fuel gauge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 12 Old 06-28-2019, 11:30 AM Thread Starter
Fuel gauge
Hi all, have 2013 DL 650 57K, recently fuel gauge has been oscillating left to right consistently regardless amount of fuel in tank, all other gauge are fine, suggestions. Thanks
John Aubin is offline
post #2 of 12 Old 06-28-2019, 01:14 PM
locoblanco's Avatar
Possibly the sending unit which is part of the fuel pump assembly in the tank. That's usually the weak point of fuel gauges in general. If everything else is ok just keep an eye on your trip meter for fuel consumption, or look in the tank like the old days. Probably not worth the cost of repair, since there are other ways to keep an eye on the fuel level.
locoblanco is offline
post #3 of 12 Old 06-28-2019, 04:36 PM
Clean the electrical connector from the fuel pump. I had that before and cleaning that connection under the tank (and adding some ACF50 inside it) resolved the problem for me.
Cryoman likes this.
uk-vstrom is offline
post #4 of 12 Old 06-28-2019, 05:16 PM Thread Starter
Thanks will give it a try
post #5 of 12 Old 06-28-2019, 10:01 PM
Brockie's Avatar
When my fuel gauge started not showing full with a full tank I cured it with a couple of tanks of injector cleaner.
BTW I have carried over from pre fuel gauge days the habit of resetting a trip meter with each fill-up.
Twangthing and Treesmacker like this.
Brockie is offline
post #6 of 12 Old 07-25-2019, 05:56 PM
My fuel gauge on my '12 650 is doing the same thing, but my bike won't start. It just keeps cranking but never catches. My bike has unfortunately been sitting idle longer than was expected and therefor was not prepped for such a long hiatus from active duty (approx 8 months). Oddly enough, it has sat for longer periods before without any issue, but this time it only had a partial tank of gas.
When I turn the key to the ON position, the speedometer needle does its thing while I hear the buzz and associated electronic clicks and stuff. I seem to recall there being a second sound like a mechanical whine, which I do not hear, and I'm wondering if that could be the key clue to why the bike's not starting. If the fuel gauge strobing is due to an iffy electrical connection on the fuel sender, could the fuel sender be the problem? Is that the "missing" sound I'm not hearing?
No need to respond if you're just going to give me sh!t about not riding it enough. I already realize that and have considered selling it, but I still need to get it running again. Any help is greatly appreciate.
2006 Kawasaki Ninja 650R / Galaxy Silver (Traded In)
2012 Suzuki V-Strom 650 / Metallic Fox Orange
http://2012v-strom650.blogspot.com
Operator7G is offline
post #7 of 12 Old 07-26-2019, 05:32 PM
Rolex's Avatar
You need to hear that whine, that is the fuel pump priming.
Could be a power to the pump problem but most likely the pump.
If the power is OK a fuel flow and pressure test would be next.
Have you tried opening the throttle while cranking ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 12 Old 07-27-2019, 10:06 AM
ddphillips's Avatar
My 12 had a similar “no start” issue after the battery was removed for a few weeks. Solved with ignition on and opening the throttle fully a few times, then it started fine, seemed to need the full TPS input before it would start
Gert likes this.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #9 of 12 Old 07-27-2019, 04:41 PM
Okay, I don't hear the whine, so I found the three-wire plug that goes to the sending unit to make sure that power is being supplied, and both "hot" leads read 11V when I turn the key to ON. I guess the next step will be to pull the fuel sending unit and see what's going on there.
post #10 of 12 Old 08-14-2019, 06:14 AM
ddphillips's Avatar
So +ve voltage at the pump, one wire is supply to the pump, one is the fuel level sender wire (a wire wound variable resistor) and the other a ground wire, could be the ground wire is open circuit. Or the pump has failed, its a 12v dc motor sitting in the tank that runs a fuel pump, no fuel pressure=no injectors spraying fuel. I have a spare pump/sender unit from my 2012.
Darren
