Fuel gauge - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #11 of 15 Old 08-14-2019, 07:17 AM
ddphillips's Avatar
Should sound like this
https://youtu.be/P1osvAjD-_w
slane6 likes this.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #12 of 15 Old 08-14-2019, 02:42 PM
Gert's Avatar
Try a jump start. Maybe the battery needs a full charge and load tested.
Gert is offline
post #13 of 15 Old 08-28-2019, 05:45 PM
I also have this issue with the occasional bout of the gear sensor being undecided which gear the bike is in on my 2012 650 - would love a suggestion as to where on earth I find the offending connector (being a mechanical Luddite).
The gear sensor plays up when it’s wet ie in the rain and would love a resolution before a winter of wet riding in the uk
Britcat100 is offline
post #14 of 15 Old 09-02-2019, 07:49 AM
Britcat, the gear connector is just above the front sprocket cover, behind the frame triangle. A good clean followed by some ACF50 in there should see you right for the UK winter.
If you haven't already, I'd also recommend you lift the tank and airbox, and do the same to the connectors above the radiator including covering them with pieces of innertube to keep the salt water out.
Gert likes this.
uk-vstrom is offline
post #15 of 15 Old 09-04-2019, 08:06 PM
Thanks for the advice - that’s my weekend jobs sorted
