Dealer mode - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-27-2019, 07:36 PM Thread Starter
Dealer mode
Hello, I'm trying to figure out how to access codes for the dealer mode. I get an intermittent FI code but haven't been able to find the connector that I could use to access the code. I saw a video for one but I guess it was for an older model v strom. I have a 2015 v strom adventure. Thanks for any advice!
Jsaul8923 is offline
post #2 of 7 Old 06-28-2019, 09:13 AM
D.T.'s Avatar
Paper clip is the cheapo way to do it.
It's under the seat by the rear turn signal (clutch side). White connector. Jump 2 wires together.
I have a switch hard wired into mine so I can see it when it happens.
D.T. is offline
post #3 of 7 Old 06-28-2019, 10:09 AM Thread Starter
Thank you! Is it a 6 pin connector or a 4? I found a 4 pin connector but the video I saw had a 6 pin. I'll look again when I'm off work today. Thanks for the reply.
post #4 of 7 Old 06-28-2019, 10:22 AM
Brockie's Avatar
Look at this thread for a pic of it. https://www.stromtrooper.com/dl650a-...e-confirm.html
Brockie is offline
post #5 of 7 Old 06-28-2019, 02:54 PM Thread Starter
Great! Thank you!
post #6 of 7 Old 07-02-2019, 09:22 AM Thread Starter
So I have a C65 code. After doing some research I found it could be my clutch sensor. I had dropped the bike and found that the sensor wouldn't let me start my bike so I shorted it for the time being. Could it still make this code appear even if the clutch sensor is shorted? I have one on the way but thought it was weird that this would cause the code to still show. Thanks again for any advice!
post #7 of 7 Old 07-02-2019, 09:36 PM
Brockie's Avatar
You seem to have found the reason for the code. ECU's work in strange and mysterious ways - an intermittent bridge etc. The new switch should resolve it.
Brockie is offline
