Exhaust from 2019 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By joeslabb
post #1 of 5 Old 06-19-2019, 05:12 PM Thread Starter
Exhaust from 2019
Is it possible to change the exhaust to new 2019 V Strom 650 exhaust on a 2013. I would love to have closer fitting bags. This should reduce the overall width in the back.
joeslabb is offline
post #2 of 5 Old 06-20-2019, 05:47 AM
Gert's Avatar
Any automotive exhaust fitter can bend an intermediate pipe to fit for your conversion. I think that there is more to it than just having a intermediate pipe changed. Have you thought of how you would go about mounting the exhaust in the lower position? If it where me, I would go have a closer look (take some pix) on how the L9 silencer / exhaust mounting bracket is secured above the swingarm. Next task would be to see if I can duplicate the mounting system / brackets on the L5, if it is not a straight bolt-on item.
Gert is offline
post #3 of 5 Old 06-20-2019, 07:01 AM
Griff2's Avatar
Would the change affect fuelling ?
Griff2 is offline
post #4 of 5 Old 06-20-2019, 11:44 AM Thread Starter
It's the same frame and you will need new brackets and sundry hardware. The computer adjust the fueling per need, should work.
Gert likes this.
joeslabb is offline
post #5 of 5 Old 06-21-2019, 06:17 PM
RevD's Avatar
I wanted to do the same thing and had a close look some time ago. There were some different attachment points for the exhaust and the pannier racks if I remember correctly. It looked to be too much work to be worth it for me. There would be welding involved at the very least.
Happy Trail racks are within 1/2” of being symmetrical and you can adapt a large number of cases to them. I think their secret is either cutting or removing the heat shield on the exhaust. I ended up just keeping the stock cases...
RevD is offline
