Harmonics around 5000 RPM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 11 Old 06-07-2019, 08:46 PM Thread Starter
I have a 2013 Vstrom 650 DL bought used. Runs well and quietly and as wished, except around the 5000 RPM mark, doesn't matter what gear. Between around 5000-5100 RPM it starts to have a growl to it. Slower and higher RPMs sound disappears.
Has anyone else noticed a similar pattern? Thoughts?
Thank you.
bandoeagle is offline
post #2 of 11 Old 06-07-2019, 08:55 PM
If it has crash bars, that is the probable culprit.
you could try googling vibrations at 4-5 K rpm.
post #3 of 11 Old 06-07-2019, 10:28 PM
Brockie's Avatar
Crash bars etc. seem to emphasise an existing harmonics issue around 4,800 rpm.
See here:
https://www.stromtrooper.com/dl650a-...ibrations.html
https://www.stromtrooper.com/dl650a-...ns-66-mph.html
Brockie is online now
post #4 of 11 Old 06-08-2019, 02:20 AM Thread Starter
Thank you. I was worried it might be something internal. Crash bars make sense and if others have experienced, probably what I am hearing.
post #5 of 11 Old 06-08-2019, 02:47 AM
Dark Angel's Avatar
You can damp it somewhat by adding some rubber into the connection between the left and right side sections where they join in front of the motor. My last set were Givi and they have a plug at the join between the two sides. I used plastic tape and rubber o-rings where the sections meet. It's not a cure so much as reducing the effect.
RestoRider2017 likes this.
Dark Angel is offline
post #6 of 11 Old 06-08-2019, 05:07 AM
Brockie's Avatar
I replaced the metal joiner between my Givi halves with one of these. It is a 12mm garden hose joiner. A perfect fit.
post #7 of 11 Old 06-08-2019, 07:55 AM
WoodRat's Avatar
That gives me something to look for in the local hardware store. There must be something similar available in the US.
K7 Vee for the road, K6 DR650 for the treks more challenging
Available for rides in S. Oregon/N. Calif., or happy to assist riders passing through the area.
WoodRat is offline
post #8 of 11 Old 06-08-2019, 08:57 AM
Brockie's Avatar
I would have thought that there would be something identical. It's a click on garden hose joiner. This one is made by Nylex, but there are Pope and Gardena as well. 13mm hose coupling.
notacop likes this.
post #9 of 11 Old 06-08-2019, 03:40 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
I like the idea if your skid plate does not attach to the cross member. If it does though you have no real structural support there. Right?
Coach23101 is offline
post #10 of 11 Old 06-08-2019, 05:03 PM
dmfdmf's Avatar
Originally Posted by bandoeagle View Post
I have a 2013 Vstrom 650 DL bought used. Runs well and quietly and as wished, except around the 5000 RPM mark, doesn't matter what gear. Between around 5000-5100 RPM it starts to have a growl to it. Slower and higher RPMs sound disappears. Has anyone else noticed a similar pattern? Thoughts? Thank you.
It may just be the crash bars that need tightening or damping or whatnot. However, if you can feel excess vibes in the seat, handle bars and foot pegs your motor my be out of balance. My 2014 DL650A that I bought in April of last year was always viby from new per the seller. It turned out the lower front throttle body was loose causing my Givi crash bars to vibrate like crazy right at 5100RPM.
Loose lower Throttle Body boot causing vibrations.
Next Up: ?
dmfdmf is offline
Tags
harmonics , vibration
