Raising Front Fender ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 11 Old 06-05-2019, 02:41 AM Thread Starter
Who?'s Avatar
Is anybody raising the front fender? Is there a kit or how is it done? Will an Shinko 805 fit under the stock fender?
Who? is offline
post #2 of 11 Old 06-05-2019, 03:41 AM
Brockie's Avatar
Yes, yes, and yes. https://www.adventuretech.biz/dl650-2012-to-2016.html
Richlandrick is a regular contributor here and runs his own cottage industry. Get a sidestand extender while you are at it.
Brockie is online now
post #3 of 11 Old 06-05-2019, 02:00 PM
Bikehigh's Avatar
I made my own brackets from a couple pieces of bar stock. Those are for the front. This was about five years ago, and Rick's kit wasn't available at the time. At the rear, drilling new holes in the plastic does the trick. Raised the fender about an inch.
Just a word of warning.Raising the fender requires the removal of any fork brace you may have, as there is no clearance. I did make my fork brace work by using a heat gun and reworking the plastic at the top of the fender to provide clearance. Ended up not using the fork brace anyway, because I don't feel any benefit, but it can be done if you're handy.
I like having the raised fender, as I do ride in Rocky and muddy conditions from time to time
notacop likes this.
Bikehigh is offline
post #4 of 11 Old 06-05-2019, 03:27 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Plenty of people did the DIY kit on Gen 1 bikes with bent sheet metal. Our kits just make it much easier. No fabrication required. We have kits for 2012+ DL650s (works with a fork brace) and 2014+ DL1000s. I dropped the kit for the Gen 1 650 when I realized it would not work with a fork brace.
https://www.adventuretech.biz/fender-raising-kits.html
If you have a Gen 1 DL650 ADV Rider is a good place to look for DIY info on this subject. Also high mounted front fenders. That requires a different brake line set up. No cross over line, just two hoses down from the master cylinder. So it would not be good for the ABS models.
richlandrick is offline
post #5 of 11 Old 06-06-2019, 04:36 AM
Big yes on Adventuretech.
Bought a bulk buy for some guys down here in Australia
Excellent to deal with, and as Brockie said cottage industry.
Support them or they are gone.
Harry
richlandrick likes this.
V-Harry is offline
post #6 of 11 Old 06-11-2019, 12:41 AM
kd70qc's Avatar
+1 on the Adventuretech kit (and the kickstand foot). I used it when I put the Mitas E-07s on my bike.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #7 of 11 Old 06-11-2019, 09:58 AM
It does as advertised, easy to install and puts the height where it should be from factory for an ADV bike.
Big B is online now
post #8 of 11 Old 06-11-2019, 12:26 PM
Webfors's Avatar
Installed Rick's kit on my 650.
Need to do the same on my new 1000. I noticed some rubbing with the 804 that the dealer installed.
Two wheelz for realz!
Webfors is offline
post #9 of 11 Old 06-12-2019, 11:58 PM
NeverSatisfied's Avatar
I already had Rick's fork brace installed, at least on my own 2012 I had no problem adding his fender-raising kit as well.
2012 DL650
2018 DR650
NeverSatisfied is offline
post #10 of 11 Old 06-13-2019, 02:24 PM
Bikehigh's Avatar
I guess my DIY brackets raised the fender to where it was an issue, and Rick's doesn't. Good to know if you like the fork brace.
Bikehigh is offline
