ignition fuse blowing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Hatchi
post #1 of 7 Old 05-21-2019, 03:58 AM Thread Starter
I've got a '12 650 with 130000km on it. Recently on a 10 day ride it cut out while sitting on 130kmh, turned out the ignition fuse had blown, replaced and continued on, 2500 km later same thing. Every time I replaced the fuse it would blow,then it didn't bike ran good, rode 100metres stopped. Trailered it home, connector under tank and above the radiator had a burnt pin and the plastic had melted, cut the 2 wires and joined them with another connector. New fuse bike started and ran good, stopped and restarted it about 10 times. Rode 100metres stopped again, blown fuse, checked wiring for burning, nothing visible, checked the usual switches etc,replaced fuse, bike starts runs ok,everything else works fine, let the bike run for about 20 minutes stopped it and started about 10 times no problem, jiggled all the wiring no effect, bike keeps running. Has anyone else had a similar problem, I've lost all confidence in it, I'm just as likely to be left stranded again. I've had it since new and this is the first time it's let me down, I've owned 3 others and never had any problems with them and I put 295000km on one of them. Thanks I'm interested to get your input
oldroberto is offline
post #2 of 7 Old 05-21-2019, 09:30 AM
You'll need to find where it's leaking to ground with a meter. Here's the schematic. Start at the battery and work your way to the left. Look for wire chafing.
marcham likes this.
Hatchi is offline
post #3 of 7 Old 05-21-2019, 10:09 AM
"Rode 100metres stopped again, blown fuse"
Suggests that you still have a short. You haven't wiggled enough wires yet. You may have to take off the panels and do a more intensive search for the short.
post #4 of 7 Old 05-21-2019, 10:30 AM
Dumb question but here goes...are you using the correct amperage fuse?
gdrew is offline
post #5 of 7 Old 05-21-2019, 01:15 PM
Are you using the factory 12v auxiliary plug?
Hatchi is offline
post #6 of 7 Old 05-22-2019, 03:00 AM
Rolex's Avatar
This is where we need GW
I think it was around 2012 some of the 650's had a problem with the wires rubbing through on the frame above your left ankle ???
It's worth a look.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #7 of 7 Old 05-22-2019, 09:01 AM
That was the thick wire bundle to the left of the coolant reservoir under the gas tank. GW thought the salt from roads may have been a factor. I wrapped mine.
Hatchi is offline
No power, blowing 30A fuse repeatedly omgyouresexy V-Strom Service and Maintenance Questions and Discussions 13 07-05-2018 09:15 PM
Ignition fuse fail and question/help... vinnyvavoom V-Strom Service and Maintenance Questions and Discussions 12 06-22-2016 03:17 PM
Fuseblock ?? bmwlarry DL650 and DL650A - 2004 to 2011 8 07-13-2015 02:14 AM
Blowing high beam fuse? V-Tom DL650A - 2012-2016 2 10-13-2014 08:57 AM
Major Electrical Fault DL1000 Sheds DL1000 from 2002-2012 58 05-04-2014 06:48 PM
