Balance your tires? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 29 Old 05-18-2019, 12:34 PM Thread Starter
RiDR's Avatar
Balance your tires?
So just had the shop replace my front tire and the bike was in and out within 20 minutes. I asked the service tech if he balanced the tire and he said yes.
This is a new shop for me and not entirely sure if i trust what i'm hearing... is it possible to mount and balance a tire within 20 minutes? and is balancing really needed anyway?
RiDR is offline
post #2 of 29 Old 05-18-2019, 01:33 PM
Rolex's Avatar
Can you see any new weights on there ??
Motorpsychology likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #3 of 29 Old 05-18-2019, 01:58 PM
PerazziMx14's Avatar
Static balancing only takes a minute as does changing the tire. The real time consumer is removing and replacing the wheel and caliper(s). So yes 20 minutes while pretty fast is not uncommon.
I use balance beads and know of others who do not balance at all unless on the rare occasion there is a vibration.
Big B and notacop like this.
PerazziMx14 is online now
post #4 of 29 Old 05-18-2019, 02:19 PM Thread Starter
RiDR's Avatar
Okay never occurred for me to look
I only see weights on my rear tire installed with the old shop but the new tire has no weights, and come to think of it never did.
I cleaned my rims last week before having the new front tire installed and never saw any weights on the front.
RiDR is offline
post #5 of 29 Old 05-18-2019, 03:43 PM
Tire shop I used to go to did the mount and balance included in the cost of the tire which was lower than a lot of the other shops in the area.
They'd be done in short order. A professional tech doesn't waste time even when you stand a watch and chat during the process. Why shops want $50+ a tire is beyond me and ridiculous.
They used a tire spinning machine to balance too.
notacop is online now
post #6 of 29 Old 05-18-2019, 04:03 PM
Originally Posted by RiDR View Post
...but the new tire has no weights, and come to think of it never did...
If it never did then maybe your bike has a well-balanced wheel assembly (less tire), and if the tire itself is well balanced, maybe no weight was required.
I've had two Wees and both of them, front and back, have required several weights, just to balance the wheel. A little more weight to balance the wheel-tire assembly.
Of course I can't say they didn't balance it, but based on my experiences, it seem unlikely they did.
As for whether balancing matters, I can't say. I've always balanced mine myself, and have experienced no balance issues.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 43K+. Love it!
HokiesRWee is offline
post #7 of 29 Old 05-18-2019, 05:07 PM
Shops want $50 per wheel because its a huge money maker for them.
post #8 of 29 Old 05-18-2019, 07:45 PM
itlives's Avatar
Most shops get paid by the book. If the book pays an hour, it doesn't matter if they do it in 20.
Alternatively, if they're swapping the engine and the book says 5 hours and it takes the more, they get paid 5...theoritically.
itlives is offline
post #9 of 29 Old 05-18-2019, 07:55 PM
Every shop I've ever been in even multi brand charge two rates (tubed/tubeless) for tire changes. It is not based on a manufacturers labor book its what the shop wants to charge.
RCinNC likes this.
post #10 of 29 Old 05-18-2019, 07:58 PM
Brockie's Avatar
"The yellow dots should be aligned with the valve stem on both steel and aluminum wheels since this is the wheel's heavy balance point. This will help minimize the amount of weight needed to balance a tire and wheel assembly. So usually, whenever you see a yellow dot, match it up with the valve stem."
Fitted correctly, there may possibly be no need for weights.
notacop, a572mike and Coach23101 like this.
Brockie is offline
Quiet & Smooth At Last FredRider Suspension and Tire Tech 41 10-26-2016 08:52 PM
Mitas, you make good tires... soberjoe DL1000A - 2014-2016 7 05-09-2015 11:41 PM
Tire balance Narcosis junky Maintenance, Tech and Products. 27 09-26-2010 04:18 PM
Which tire Manufacturers mark their tires? Tollster General V-Strom Discussion 12 09-03-2008 09:20 PM
Tourance tires mounted, change in handling stevet General V-Strom Discussion 15 07-02-2008 03:16 PM
