Spoked wheel losing air DL650 XT - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 3 Post By Motor7
  • 3 Post By Berksglh
  • 1 Post By Fynlcut
post #1 of 9 Old 05-16-2019, 08:09 AM Thread Starter
Hi,
Recently bought a used 2015 model DL650 XT with spoked tubeless wheels. Front tyre is losing air. I have already taken out valve core and cleaned. Cannot see any knocks on rim, looks all pretty good. No holes in tyre?
Any ideas where it could come from or how to find leak?
Franconian is offline
post #2 of 9 Old 05-16-2019, 08:31 AM
Motorpsychology's Avatar
Originally Posted by Franconian View Post
Hi,
Recently bought a used 2015 model DL650 XT with spoked tubeless wheels. Front tyre is loosing air. I have already taken out valve core and cleaned. Cannot see any knocks on rim, looks all pretty good. No holes in tyre?
If the wheel is off the bike, submerse the wheel and tire to the level of the spoke nipples. Rotate the wheel slowly looking for air bubbles rising. Alternatively, fill a spray bottle with a soap & water solution and spray the tire in small areas, looking for telltale bubbles emanating from the leak. Locating a leak coming from the spoke nipples may be more difficult to pinpoint this way, however. But the leak is more likely to be in the tire carcass or rim-bead contact area.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
post #3 of 9 Old 05-16-2019, 08:47 AM
Motor7's Avatar
The DL spokes do not penetrate the rim/tire cavity. The spokes attach to a vertical fin that is part of the rim. Ruling out spokes, that leaves the tire or the valve stem.
MP is right, easiest way is to submerge the tire and rim to find the leak. Have a tire plug on hand and it's an easy fix.
If you have metal valve stems, I have found that due to the fin, the stem hole is not a flat surface which has given me an intermittent leak.
'15 DL650XT
Motor7 is offline
post #4 of 9 Old 05-16-2019, 09:01 AM
Berksglh's Avatar
Location: I'm most alive when I'm in the north woods on my V2. So lets say Mountain Wi.
Dont overlook the tire bead. I have same spoked tubeless rim on rear of my trials bike.
If any dirt worked its way between tire and rim while low PSI offroad, it will leak untill you remove and clean tire and rim.
If someone dammaged the ture bead spooning it,on,or off at one time, it may never be air tight, but you can try a bead sealer on tire and lube up goot when mounting and seating. On a 2 wheeled bike, if bead is bad, I would just replace tire.
Air it up and dunk in water, lok for bubbles. If slow, it may be 1 small bubble every 5 seconds.
Sent from my RS988 using Tapatalk
Berksglh is online now
post #5 of 9 Old 05-16-2019, 09:14 AM
stevet's Avatar
There is one last thing to consider. Let's assume the wheel rim was formed from straight bar stock, bent into a hoop, and welded. (Or, maybe the rim is cast metal.) Maybe it is an imperfect weld, and air is escaping from the weld. Or if a cast rim, air leaking from a casting imperfection.
I mention this because I rebalanced my front wheel a couple days ago. As it slowly spun on the balancer jig, at a spot across the diameter from the valve stem I saw what appeared to be a slightly blemished spot, like what is left over after a grinder cleans and shapes a weld. Highly unlikely leak location, but not impossible. This weld joint, if this is what it is, should be visible on the inner face of the rim when the tire is off.
Air leak locations- valve stem and stem mounting, tire carcass, tire bead/rim seating, and the rim itself.
Steve.
stevet is offline
post #6 of 9 Old 05-16-2019, 10:47 AM
Fynlcut's Avatar
Soapy water.
Spray the whole thing. (Get it good and soaked)
Look for any obvious bubbles. Generally the faster the leak, the bigger the bubbles will form and the easier they are to see.
If you see nothing, wait 5 minutes.
Look again. At this point the bubbles will probably be more of a foamy pile of tiny bubbles.
If nothing, rotate the wheel 90 degrees and start over.
Berksglh likes this.
Fynlcut is offline
post #7 of 9 Old 05-16-2019, 11:05 AM
Motor7's Avatar
Three an 4 spoke wheels are all cast aluminium. The true multi spoke wheels are extruded aluminium.
'15 DL650XT
Motor7 is offline
post #8 of 9 Old 05-16-2019, 11:30 AM
stevet's Avatar
Multi spoke, extruded. So there will be a weld joint, correct?
Steve.
stevet is offline
post #9 of 9 Old 05-20-2019, 06:41 AM
Motor7's Avatar
Yes correct.
'15 DL650XT
Motor7 is offline
Front wheel spacer DL650 ABS Navigator DL650 and DL650A - 2004 to 2011 3 09-17-2018 08:27 PM
Has Owning My DL650 Saved Money ? XLonDL650 General V-Strom Discussion 48 09-10-2018 11:23 PM
2012+ DL650 front wheel removal NeverSatisfied Maintenance How-to 2 07-12-2014 01:13 PM
SV650 front wheel installation on a DL650 exploring/carolina V-Strom Modifications and Performance 53 06-12-2014 02:54 PM
