I broke something with my clutch ... HELP - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 21 Old 05-11-2019, 03:07 PM Thread Starter
So, some years ago someone knocked over my glee-strom in a parking lot, onto the left side. The hand guards took the brunt of most of the fall, but my clutch lever has been a little wobbly since then, with vertical play that I just kind of lived with. I figured it was either the lever being a little bent, or the housing (surrounding two holes) being a little stretched.
So today, I figured I'd had enough of that. I removed the left hand guard, removed the clutch lever, and put in a new lever. It still had vertical play. I took that out, and used a pair of pliers to true up the bolt holes that line up for the clutch lever, and reassembled it. That did the trick, the lever no longer had play.
I reassembled my hand guard and took it for a test ride around the block. Immediately, I noticed the lever pull seemed tighter (harder to pull than before), and the bite point to engage a gear was way, way late. I didn't remember changing the clutch cable tightness, but maybe something about just swapping in a new lever had done it.
I went home to adjust the clutch cable, and downshifted to first gear as I rode up my driveway... And... Ka-chunk! My gear shift foot lever just came free!
Well now there was no changing gears at all. I had to pull in the clutch to power walk the bike around, and then leave it in first gear in my garage.
I'm pretty sure these two pieces are supposed to be attached. Did I shear off a bolt somehow? I don't see how they're supposed to join.
robardin is offline
post #2 of 21 Old 05-11-2019, 03:13 PM Thread Starter
So looking at this Suzuki part diagram,
https://www.suzukipartshouse.com/oem.../gear-shifting
this is #27 (Arm, Gear Shift Link), 25520-27G00 ... and I've sheared it off somehow.
What I can't tell is how I'm supposed to remove it with bolt #36, I don't see any kind of a head that I could use to pull it out. Nor how it's supposed to attach to #34, "nut".
robardin is offline
post #3 of 21 Old 05-11-2019, 04:17 PM
branthopolis's Avatar
Part is broken. Loosen the jam nut (34) on that end of the shift rod and the piece in your hand will rotate right off. Remove the bolt (36) at the bottom of the other half.. Fully remove the bolt as it rides in a channel on the spline, and that part will slide right off. Search on Ebay for a cheap used replacement or purchase new (27) from a Dealer.. Replacement is easy as pie, repair of the broken part not easily done....
K9 Wee likes this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #4 of 21 Old 05-11-2019, 04:22 PM Thread Starter
Yeah, a forum search found this which sounds/looks exactly like what happened to me:
https://www.stromtrooper.com/dl650-d...le-riding.html
Now, after I fix this, I guess I need to adjust my clutch cable for the bite point weirdness? Seems suspicious that the same time as that, my shift link arm snaps, too.
It's not like did a super hard shift, either, I wouldn't say, though it did refuse to shift down and stayed in neutral despite several taps before just coming off (while downshifting into first, or else I'd have had to walk the bike up my driveway).
robardin is offline
post #5 of 21 Old 05-11-2019, 04:29 PM
Not saying its what caused this, but if it has been many years on the bike, now might be a good time to lube or install a new clutch cable if your clutch has a weird bite point/feel...
~Mark
2015 DL1000A
2005 YZ250
post #6 of 21 Old 05-11-2019, 04:45 PM Thread Starter
It didn't before I changed the lever, I figure I must have accidentally adjusted it somehow in tugging on it to put in the new lever.
Any good aftermarket clutch cables for this bike? I put in a motion pro one on my Vulcan 750 years ago, but this bike (a 2012 DL650) is still on its original cable. It's been lubed though, and only at around 35,000 miles (I haven't ridden as much in the past 2-3 years but hope to start riding more again).
robardin is offline
post #7 of 21 Old 05-11-2019, 04:49 PM
If it still moves freely, isn't kinked or frayed anywhere, and has been lubed periodically, it's probably fine.. Many people just don't pay any attention to them at all until they fail...
~Mark
2015 DL1000A
2005 YZ250
post #8 of 21 Old 05-11-2019, 04:54 PM
STCorndog's Avatar
On stuff like this, that could leave you broke down, I would get the parts from Suzuki.
There are 2 adjustments on a cable clutch. One is done at the motor to set the free-play for the clutch push rod and should be done first. The second is to get the free play correct on the cable. I have no explanation for the timing, except crap like that happens to me also.
Big B and Makonasson like this.
STCorndog is offline
post #9 of 21 Old 05-11-2019, 05:01 PM Thread Starter
Yeah, I have only ever adjusted the free play at the top of the cable near where it attaches to the lever, and I don't think I've adjusted it on the v-strom except maybe a bit the first time I got it to where I like it.
Hopefully this part replacement is simple, I just wish I wasnt losing riding time just when the weather finally got nice! I was about to change my oil, too!
Big B and STCorndog like this.
robardin is offline
post #10 of 21 Old 05-11-2019, 10:49 PM
Brockie's Avatar
I have never been able to replace a clutch lever without first winding in the adjuster to lengthen the cable free play. Could you have wound the adjuster in, and then not wound it back out to the correct lever free play? Did you check lever free play after installing the new lever?
The dragging clutch might have caused you to put far more force than usual on the gear shift lever. It is a very unusual part to break.
Big B likes this.
Brockie is offline
06 Wee Clutch Engagement Problem tetsuo69 DL650 and DL650A - 2004 to 2011 7 06-05-2015 11:04 AM
Need Clutch Help Strange Dog DL1000 from 2002-2012 12 03-25-2015 11:11 PM
I am sorry but, another frigging clutch question. carlrf DL1000 from 2002-2012 33 10-29-2014 10:01 AM
Extended clutch arm? SRTeric DL650 and DL650A - 2004 to 2011 1 09-02-2012 02:47 PM
Help, clutch won't disengage! mirage V-Strom Service and Maintenance Questions and Discussions 13 06-04-2008 10:22 PM
