Suzuki Adv. bags - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-10-2019, 09:57 AM Thread Starter
Suzuki Adv. bags
Does anyone know if any other bags/panniers will fit the 2014 wee factory side brackets for the adventure model with the large hard cases? Just looking for a smaller bag/pannier size. Looking to buy a bike listed locally that already has the adventure bags on it.
Thanks,
Barender
Barender
barender is offline
post #2 of 5 Old 05-11-2019, 04:06 PM
cyclopathic's Avatar
OEM bags are rebranded SW Motech EVO any compatible with EVO panniers will fit. Second you can also get a Motech mount kit and install it on your choice of bags. Third Motech sells a conversation kit to make frames compatible with Givi.. check twisted throttle good luck.
cyclopathic is offline
post #3 of 5 Old 05-11-2019, 04:46 PM Thread Starter
Thanks,I appreciate the information.
Barender
Barender
barender is offline
post #4 of 5 Old 05-11-2019, 09:04 PM
Do these racks for Wee2 fit on Wee?
Rick123 is offline
post #5 of 5 Old 05-12-2019, 05:00 AM
Never tried. Very likely as I don't think mount points changed but could be wrong.
BTW Evo Motech are Starbucks POS. Due to combination of toilet paper thin sheet aluminum, lack of metal under plastic corners and flimsy rivet job they will stop being waterproof after 0mph parking lot drop. Motech addressed these issues with Ion which looks almost identical but have welded seams and metal in corners.
If you want ADV worthy cases get these:
https://youtu.be/Vb-eL02LAq0
They use Touratech mounting system and should be compatible with Motech frames good luck.
Pannier bags for the Suzuki Adventure Panniers??? boonekerley DL1000A - 2014-2016 15 08-18-2015 02:42 PM
Adventure Top Box Discontinued?! zildjian DL650A - 2012-2016 25 11-11-2014 11:41 AM
DL1000 New Recall ghostrider66 DL1000 from 2002-2012 60 09-15-2011 04:36 PM
Suzuki Charging System Failure Recall prothos General V-Strom Discussion 1 02-28-2011 09:37 AM
