Super sensitive throttle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 20 Old 04-29-2019, 08:03 PM Thread Starter
VSrider's Avatar
2012 650 My throttle has always been twitchy from on to off at slow speeds but it seems to be getting worse. It's really hard to hold a steady speed below 30 mph. It's not a cable slack problem. TPS maybe? Any ideas?
VSrider is offline
post #2 of 20 Old 04-29-2019, 08:13 PM
Webfors's Avatar
I think all DL650's behave that way. But you say it's getting worse...
A search turned up a few threads on the forums regarding TPS adjustments:
https://www.stromtrooper.com/v-strom...djustment.html
Two wheelz for realz!
Webfors is offline
post #3 of 20 Old 04-29-2019, 08:19 PM
My 2013 DL650 is as smooth as butter at low speeds great for when leaving the Lions shop after a game of rugby & slowly pushing thru crowds on the footpath .
Something must be up
iamsmiling and V-Harry like this.
DL650A L3
KLR650
CB900 Bol d'Or
Yamaha Nifty Fifty ( great way of saving for university )
RD350LC
CB125twin
Farm Bike Suzuki Van Van 125
reasonable is offline
post #4 of 20 Old 04-29-2019, 09:24 PM
BC Rider's Avatar
My 13 is smooth putting around in second through crowded areas. perhaps some injector cleaner
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #5 of 20 Old 04-29-2019, 09:46 PM
Wow that's weird, my 15 does nothing as which you describe. Might consider a throttle tamer, they aren't cheap but I understand work as advertised.
Big B is online now
post #6 of 20 Old 04-29-2019, 10:06 PM
sbeadg's Avatar
I had a '16 CB500X that had that issue. Very tricky to modulate the throttle on rough roads. It just needed more friction so I took a length of bailing twine and tied it between the throttle and the brake lever housing. Worked a treat!
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #7 of 20 Old 04-29-2019, 10:07 PM
sbeadg's Avatar
Just to clarify. I wrapped it around in the space between them...
'15 Tiger800 XRx
'89 Honda NX250
sbeadg is offline
post #8 of 20 Old 04-29-2019, 11:13 PM
blaustrom's Avatar
How many miles?
TPS adjusting:
https://www.stromtrooper.com/dl1000a...ottle-off.html
Read through that thread. It's for the V2 but I assume yours is not too different. Do you have the service manual? It has the instructions how to set the TPS. Apparently many are not set correctly and it may effect how the bike is behaving.
The reference in #2 is for the WEE and I don't think the new 650 model has the same procedure.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 20 Old 04-30-2019, 12:13 AM
Rolex's Avatar
Also check you have no slack in the pull cable.
There is a cam on the end of the throttle tube, that cam has a lump, if you have slack in the cable you will hit that lump much earlier, this causes the throttle to open more and early so you shut it off thus causing the snatch.
I fitted a throttle tamer to my V2 and I'm happy with the results .
Motor7 likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 20 Old 04-30-2019, 07:18 AM Thread Starter
VSrider's Avatar
Originally Posted by blaustrom View Post
How many miles?
69,000 miles
VSrider is offline
Throttle not fully returning adventurebiker DL650 and DL650A - 2004 to 2011 18 04-28-2014 02:30 AM
Kaoko Throttle Lock Cruise Control was Before I Pull The Credit Card Out .... Harry Dresden PI DL650A - 2012-2016 23 03-31-2014 04:28 PM
NEP throttle lock installation on 2011 Wee Benly DL650 and DL650A - 2004 to 2011 0 06-15-2011 01:25 PM
Crunchy throttle after heated grip installation bunner bob General V-Strom Discussion 3 11-23-2007 02:11 PM
