Stator Rewiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 13 Old 04-26-2019, 08:52 PM Thread Starter
Grey Ghost's Avatar
Stator Rewiring
My Vstrom died on me in Walcha
Flat Battery no charge from Stator.
Original Suzuki stator 670 Australian dollars.
Getting rewind done for 350.
Any other upgrade parts I should consider while getting work done.
2015 XT 650
Grey Ghost is offline
post #2 of 13 Old 04-26-2019, 09:16 PM
Wish you well on the re-wind, they don't tend to last long. Suzuki fixed the stator issues "reportedly" with the recall, when/if this one fails prematurely I recommend going with the latest OEM unit.
Hard miles and Hatchi like this.
Big B is online now
post #3 of 13 Old 04-26-2019, 11:20 PM Thread Starter
Grey Ghost's Avatar
Does OEM cost of 650 Australian sound right?
I've noticed EBay units for 130 or less.
The company specialist in motorcycle components
https://www.smallcoilrewinds.com.au/
post #4 of 13 Old 04-26-2019, 11:54 PM
jeeves's Avatar
Why not?
I know a few people here in Croatia that have done it on their 650's.
Been working without a problem for years now.
If the person doing the rewinding knows what he is doing, and is using well insulated wire it should be fine. Much cheaper then OEM or aftermarket.
Sent from my Redmi 4 using Tapatalk
Don't ask...
jeeves is offline
post #5 of 13 Old 04-27-2019, 12:07 AM
blaustrom's Avatar
The re-wind outfit seems to be a solid company. I would start another thread asking specifically the Australian forum memebers if they have experience with this company or if they can recommend an alternative.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 13 Old 04-27-2019, 04:38 AM Thread Starter
Grey Ghost's Avatar
The guy who started it worked for Kawasaki Australia
When out on his own 8 year's ago.
We know OEM burn out at 45 - 55 k Ks so I figure after market specialist gota be as good or better
I'll update progress
post #7 of 13 Old 04-27-2019, 10:11 AM
Yes the faulty stators did, have yet to hear of a single failure from the newest/latest model. Sounds like who did yours knows what he's doing, nothing quite like a reputable small business to do top quality work.
itlives likes this.
Big B is online now
post #8 of 13 Old 04-27-2019, 11:06 AM
2015 XT 650
Does that 650 generation suffer from loose rotor magnets? In that case, while you've got that side of the engine opened up, I would do the JB Weld reinforcement at the same time. Can't hurt.
BackPacker is offline
post #9 of 13 Old 04-27-2019, 11:48 AM
jeeves's Avatar
650 have had a one piece magneto for a long time. I think from 2006 or something like that.
Don't ask...
jeeves is offline
post #10 of 13 Old 04-27-2019, 04:56 PM
2015 XT 650
If you go this rewind route, I strongly recommend that you pay a little extra to have the new magnet wire be the type with the highest operating temperature rating. The wire will cost more and may require extra procurement effort, and terminating it will require some extra labor, but it will improve longevity. I know for a fact that the Suzuki stator is being run much hotter than ordinary magnet wire can reliably tolerate.
The advice given above to replace the failed stator with the recently released revision is good. If Suzuki has had it wound with that higher-temp wire, it is a good solution.
Trepidator is offline
