Coolant overflow bottle. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By blaustrom
  • 2 Post By locoblanco
post #1 of 5 Old 04-24-2019, 09:30 PM Thread Starter
Somebody please tell me that I do not have to pull the gas tank to top up the antifreeze overflow bottle on my new to me '13 DL650. I'm finishing up my list of routine maint. items and will test ride the bike tomorrow. Today I noticed the fluid was a bit low (I like to set it about 1/4" below the top mark on the bottle) and a. realized it is going to be a chore, b.I cannot see the low and high fluid level marks.
Are these Suzuki engineers for real? Why didn't they put the throttle bodies on top of the bottle to make this a REAL challenge? Oops, now that I suggested this they might do it for the 2020 model year.
Ratchet is offline
post #2 of 5 Old 04-24-2019, 09:57 PM
Brockie's Avatar
With respect, you are being a little too anal about this. If your fluid level is between the upper and lower limits, leave it alone.
I have never needed to top up my radiator overflow bottle.
Brockie is online now
post #3 of 5 Old 04-24-2019, 10:06 PM
blaustrom's Avatar
+1
But Ratchet, you are correct. On my V2 you have to do major surgery to get to the reservoir. But I have never touched it other then changing the fluid and that coincides with doing the valve check, means the bike is stripped down already.
eff likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 5 Old 04-25-2019, 03:09 AM
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
I think I saw a post in a thread from Graywolf where he used a syringe or something like that to backfired coolant 8nto the tank through an overflow hose. Maybe at the radiator cap? I could be wrong, but I think I saw something like that. Might be worth a few minutes with Dr. Google.
Having done it a few times now, it only takes me 15 or 20 minutes to pull the tank, btw. It's not that difficult. Although, I agree, it seems kind of dumb to have to do that to add coolant.
Vinnie
Sent from my SM-T800 using Tapatalk
Currenv is offline
post #5 of 5 Old 04-25-2019, 08:32 AM
locoblanco's Avatar
It's not necessary to remove the tank to access the coolant reservoir, but you will need to raise the rear end of the tank. It's a bit of a chore, but that's the result of having a lot of technology packed into a relatively small area. The vstrom is certianly not the only vehicle, (bike or car), to suffer from this.
a572mike and MAZ4ME like this.
locoblanco is offline
Brief temp gauge spikes (4 bars) after coolant replacement goweego DL650 and DL650A - 2004 to 2011 9 05-22-2018 10:22 AM
4 codes and cloudy coolant Nelsonmd DL1000 from 2002-2012 3 11-12-2016 10:31 PM
Broken Coolant Overflow Tap Fix? Brahms DL650 and DL650A - 2004 to 2011 5 05-10-2012 07:40 PM
Splattered Coolant - Overflow or Leak? swingle12 General V-Strom Discussion 2 10-11-2009 10:51 AM
Coolant leak(from the overflow hose)!!! snatch V-Strom Service and Maintenance Questions and Discussions 16 01-28-2008 06:54 PM
