Maintenance Time! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #11 of 27 Old 04-23-2019, 10:10 PM
I changed the stock plugs at 60K miles and they were still fine. Iridium has a good reputation but the originals work many long time too.
post #12 of 27 Old 04-23-2019, 10:34 PM Thread Starter
Webfors's Avatar
Sounds like I can push the plugs out. What’s the iridium part number equivalent?
So air filter and brake fluid swap is warranted.
I noticed the manual states replacing the brake hose at 4 years?! Are we taking all of them? Seems excessive.
Two wheelz for realz!
Webfors is offline
post #13 of 27 Old 04-23-2019, 10:52 PM
STCorndog's Avatar
Originally Posted by Webfors View Post
Sounds like I can push the plugs out. Whatís the iridium part number equivalent?
Just have a dealer cross reference the plugs to iridium. I only ran my standard plugs to around 30,000 miles. As for brake hoses, it depends. If the bike stays indoors or covered, they last a lot longer. Just visually examine the rubber outer coating of the hoses for hair line cracks or dry rot.
You have 2 sets of brakes....what could go wrong
Webfors likes this.
STCorndog is offline
post #14 of 27 Old 04-23-2019, 11:31 PM
Iím almost positive that the 12 and up 650 come with iridium plugs from factory.
1997 Honda Valkyrie 1500 custom ďDoloresĒ
post #15 of 27 Old 04-24-2019, 12:07 AM
Highwayman2016's Avatar
Maintenance Time!
My 2014 did, changed them at 30,000 miles.
Webfors likes this.
2014 650 Strom
Highwayman2016 is offline
post #16 of 27 Old 04-24-2019, 07:20 AM Thread Starter
Webfors's Avatar
You are correct, NGK CR8EIA-9 is iridium.
In which case it makes the maintenance interval for plugs insane, no?
Webfors is offline
post #17 of 27 Old 04-24-2019, 07:26 AM Thread Starter
Webfors's Avatar
Originally Posted by notacop View Post
Coolant, Mine is 15 years old, is that a problem? the bike runs fine and never gets over 3 bars and doesn't see freezing temps very often. If you don't ride in really dusty conditions, the air filter probably only needs a blast of compressed air.
Brake fluid, if the window in the reservoir is dark, it's probably a good idea. http://kirbysbrakebleeders.ecrater.com/ these make the job simple.
This is the think of the non AR less is more maint. I'm probably wrong though.
Ok, just read up on speedbleeders... this is a must if I'm going to do regular fluid changes. Thank you!
Now, which part number to add to all 3 of my 2015 DL650 calipers?
Webfors is offline
post #18 of 27 Old 04-24-2019, 08:15 AM
Yup, at 20K miles mine still look new.
Webfors likes this.
post #19 of 27 Old 04-24-2019, 09:25 AM Thread Starter
Webfors's Avatar
Found it:
https://kirbysbrakebleeders.ecrater....speed-bleeders
I'll need a small plastic tube to fit on the end of the bleeders and I'm set. Should make this task quick and easy.
Webfors is offline
post #20 of 27 Old 04-24-2019, 09:47 AM
Yah, the rear master cylinder is a bother to get at with the luggage bolted in place but I was able to use a funnel and tube to get at it and only pry the plastic cover out a little bit.
the whole process only took a few minutes.
Webfors likes this.
80k mile - 125k km ..maintenance Macdoc DL650 and DL650A - 2004 to 2011 4 07-01-2017 08:18 AM
Remember your first time...? ommoran Maintenance, Tech and Products. 8 04-16-2017 12:19 PM
Long time lurker, first time poster EmptiMind Stromtroopers - New member introductions 3 02-26-2014 01:06 PM
Time to move on, I think... sfdyoung General V-Strom Discussion 51 12-22-2013 09:34 AM
My Day @ Barber Motorsport ChiGuy64 Riding Proficiency 12 06-04-2013 08:39 PM
