ABS light on - what do I check? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 16 Old 04-20-2019, 09:25 PM Thread Starter
bajakirch's Avatar
On my morning commute my ABS light came on and is now staying on. The manual doesn't say anything other than 'something's wrong, take it to the dealer'.
Any ideas on what I should start checking?
bajakirch is offline
post #2 of 16 Old 04-20-2019, 09:58 PM
On my Beemers, it may have been the gap of the sensors to the rings or a bit of metal stuck in the sensing wheel. Funny how cars never seem to have that sort of failure and Bikes seem to be a mind boggler.
post #3 of 16 Old 04-20-2019, 10:44 PM
Wonder if a reset (disconnect battery/reconnect battery) will clear the fault? Might be worth a try to see if it repeats. I clearly don't know enough about ABS to offer anything other than a shot in the dark. Good luck with it!
gdrew is online now
post #4 of 16 Old 04-20-2019, 11:58 PM
blaustrom's Avatar
This is not a common problem but do a google search at stromtrooper and you will find a few threads I think.
I would try and find the fuse the feeds the ABS and make sure its ok and has good contact. Then check both wheel sensors (remove them - 8 mm socket and make sure there is no gunk clinging to the front) and the associated wiring. If all that checks out you need to find better suggestions form someone else here.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #5 of 16 Old 04-21-2019, 10:52 AM
You ride/own a 2012 by chance?
post #6 of 16 Old 04-22-2019, 09:55 PM Thread Starter
bajakirch's Avatar
Yep.
I checked the front sensor yesterday and found the bolt holding it in place was loose, so I tightened it up. The light went off as normal...then came back on about 15 miles down the road.
Before I rode home I checked the sensor and the bolt was tight. I quickly checked the wiring as far up as I could and didn't find anything obvious. The ride home the light turned off as normal, and was fine for my ride in this morning.
On my way home, it was fine again. Then I ran into a rain storm and pulled over to eat dinner and let the storm pass. Once it did, I started up the bike and the light was on again for the whole ride home.
As soon as I can find some garage time, I'll try the battery disconnect and fuse check.
post #7 of 16 Old 04-23-2019, 09:51 AM
blaustrom's Avatar
Sounds more like an electrical problem ... BUT ... just in case, are you running non stock size tires front or rear?
Blau2 2014 DL1000A
post #8 of 16 Old 04-23-2019, 11:35 AM
Rolex's Avatar
Have you had your rear wheel removed recently ?
Leaving the sensor in place when the rear wheel is removed can damage the rear sensor.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #9 of 16 Old 04-23-2019, 08:22 PM
Webfors's Avatar
Now I'm getting paranoid about ABS
Is there a general ABS troubleshooting and maintenance checklist that we can adhere to? Might be time for a sticky with that content. I'll volunteer to put something together if it doesn't exist already.
Two wheelz for realz!
Webfors is offline
post #10 of 16 Old 04-23-2019, 09:32 PM Thread Starter
bajakirch's Avatar
I am...I have Shinko 705s front and rear. But I'm on my third set since swapping out the stock Trailwings and this is the first time I've experienced this.
Yes, I took it off this winter to replace the rear tire. However I did follow the manual's instructions to remove the rear sensor before taking off the wheel, and replaced it once the job was done.
Webfors likes this.
Throttle Body Butterfly Sync (NOT idle air needle adjustment sync) dmfdmf V-Strom Service and Maintenance Questions and Discussions 1 04-11-2017 03:56 PM
AdMore Lighting's SM Light Bar Joe Shablotnik General V-Strom Discussion 0 06-30-2016 11:49 AM
LED Tail Light (No eBay links allowed) garandman V-Strom Modifications and Performance 47 06-12-2013 10:49 PM
check light David DL650 and DL650A - 2004 to 2011 2 04-26-2009 05:20 PM
