HELP! ABS module is dead - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 50Likes
post #11 of 58 Old 04-19-2019, 11:27 PM
blaustrom's Avatar
Originally Posted by rambunkshuss View Post
I will try this method! and, no....I did not ever change the brake fluid.
Let us know, what you find! A lesson learned for everybody else, change that fluid regularly. That fluid is hygroscopic = it absorbs moisture. Corrosion inside the ABS module can become an expensive consequence of deferred maintenance in this case.
Also it is prudent to activate the ABS regularly to move fluid that has been sitting in the ABS module out and exchange it as well as exercising those valves.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #12 of 58 Old 04-19-2019, 11:30 PM
blaustrom's Avatar
Originally Posted by p38arover View Post
Threads merged. Don't post the same question in multiple areas.
Thanks! I thought already I am loosing it, having posted a response and then seemingly it was gone …. and I tried to find those links again.
p38arover likes this.
Blau2 2014 DL1000A
post #13 of 58 Old 04-19-2019, 11:38 PM
It might be also as simple as collapsed wall of the rear brake flex line.
Rick123 is online now
post #14 of 58 Old 04-19-2019, 11:41 PM
Administrator
Wow yet another 12 with abs pump issues......something is up with that model year and or build dates.
post #15 of 58 Old 04-19-2019, 11:43 PM
Administrator
True, except only the 12’s are having issues, I believe ABS 650’s started in 09?
post #16 of 58 Old 04-20-2019, 05:24 AM
Most likely is an overfull rear reservoir. If you havn't looked at that first please do that first.
Second is crap caught between the pistons and caliper.
Note that the ABS unit shouldn't be capable of failing like this as it's effectively a bypass on the braking system and doesn't activate unless the ABS function kicks in. Brake pedal slowly heading for the bottom of travel when applied would match a faulty ABS unit.
PeteW is online now
post #17 of 58 Old 04-20-2019, 12:36 PM
dmfdmf's Avatar
It does seem that Gen2 ABS modules (2012-2016) have a slightly higher failure rate than Gen1. FYI, Gen1 ABS was an option in 2007, 2008 & 2009 (there was no 2010 model) and became standard in 2011 and beyond. The ABS motor/valve were redesigned for Gen2 to weight less and use less power.
I agree, the ABS is designed to "fail safe" meaning any failure won't interfere with the normal operation of the brake. I'm not sure what the OP means by "I can't depress my rear brake pedal" but if it is locked or doesn't move then something is wedging the operation of the pedal linkage, frozen master cylinder, jammed caliper pistons, etc. The ABS is almost certainly not the problem here.
Gert and Motorpsychology like this.
Next Up: ?
dmfdmf is offline
post #18 of 58 Old 04-20-2019, 04:07 PM
DC_Dave's Avatar
I feel your pain. I haven't changed my rear fluid as much as I should b/c the reservoir is out of sight out of mind.
My understanding is that an ABS failure mode includes locking out the rear brake (as you describe), as well as locking the rear brake.
You may be able to rig up an ABS exercise switch harness to cycle the rear channel solenoid with fresh fluid.
Regardless, you should be able to fit a non-ABS brake line between the rear master cylinder to restore normal braking.
DC_Dave is offline
post #19 of 58 Old 04-20-2019, 07:18 PM
rooster shooter's Avatar
Still expensive but Partzilla has it for $1382. https://www.partzilla.com/product/suzuki/55610-11J01
rambunkshuss likes this.
'13 GL1800
'17 DL650A
rooster shooter is offline
post #20 of 58 Old 04-21-2019, 03:02 PM
DC_Dave's Avatar
Why would anyone replace the ABS module for a rear channel failure? You really only need it for the front wheel. Just hook up a hose from the rear master cylinder to the caliper and call it good.
Webfors likes this.
DC_Dave is offline
