Engine Temperature Warning -- No Red Light, 3 bars on gauge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 04-13-2019, 04:57 PM Thread Starter
Hi all,
As described in the title:
I have three bars showing in the temperature gauge and don't seem to be noticing anything odd sound-wise.
The red light is *not* on.
However, the engine temperature warning symbol is on -- I have coolant, I have oil. Is this something that I should be concerned about? Is this something I can address on my own?
Regards,
Kyle
kwestl is offline
post #2 of 14 Old 04-13-2019, 05:02 PM
BC Rider's Avatar
I must admit that I didn't know there was a engine temp warning. There is a cold air warning(snowflake). And three bars is normal.
13 DL650
80 CX500D sold and missed
BC Rider is offline
post #3 of 14 Old 04-13-2019, 05:07 PM Thread Starter
I'm very familiar with the cold air warning and had a brief scare when my fan went out and the three bars maxed out (mechanic forgot to reconnect the fan), along with a red warning light.
However, this is the very first time I've seen an engine temperature warning.
kwestl is offline
post #4 of 14 Old 04-13-2019, 05:24 PM
There is no temperature warning symbol as far as I know. Coolant temperature symbol is always visible. 3 bars on the gauge is normal. High coolant temperature warning means all 5 bars visible on the gauge, coolant temperature symbol blinking and red light lit (below low temp warning light).
2015 DL650XT
Anduril is offline
post #5 of 14 Old 04-13-2019, 05:30 PM Thread Starter
Hi Anduril,
There is definitely an engine temperature warning icon; however, as I mentioned, the coolant temperature bars are within their normal range for me.
So this is weird.
kwestl is offline
post #6 of 14 Old 04-13-2019, 05:38 PM Thread Starter
Proof is the ye olde pudding.
I'm guessing a sensor is bad, because it's probably been 45 minutes to an hour and I /just/ turned it on with that warning still on the dash.
Or maybe it's a check-engine equivalent?
kwestl is offline
post #7 of 14 Old 04-13-2019, 05:39 PM
I don't think so, i have checked the manual Show us a photo of your dash and it will be clear.
If you mean the temp symbol below Gear indicator, then this one *is always visible*. It starts blinking along with visible red warning light, when all 5 bars are shown on the temp gauge and temperature raises to/above 120C. There is no other temp symbol.
EDIT: On your photo, this is perfectly normal condition. Google other V-Strom dashes, if you don't trust me or check the manual.
2015 DL650XT
Anduril is offline
post #8 of 14 Old 04-13-2019, 05:40 PM Thread Starter
Hey buddy,
I included a photo probably as you were typing your post. It's just above your response here.
kwestl is offline
post #9 of 14 Old 04-13-2019, 05:44 PM Thread Starter
I must just be losing my mind or never noticed it before! Had a long ride for the first time this season in the humidity after a few hours of heavy work.
So just to clarify my sweat-addled brains, while the engine is running, it's normal for the Engine-Temperature indicator there to be on and I should disregard it in favor of the coolant temperature to its immediate right.
I appreciate your patience while I cool off from the work and slide back into normal-brainpower.
kwestl is offline
post #10 of 14 Old 04-13-2019, 05:48 PM
No problem
It is just a symbol for the coolant temp gauge (bars), so it's perfectly normal that it is visible. When it starts blinking (along with red light lit and 5 bars shown), then your are in trouble
2015 DL650XT
Anduril is offline
Tags
engine temperature , warning , warning light
Brief temp gauge spikes (4 bars) after coolant replacement goweego DL650 and DL650A - 2004 to 2011 9 05-22-2018 10:22 AM
Voltage warning light going red PNWEric DL1000 from 2002-2012 25 02-26-2017 11:04 PM
CHEC light after changing coolant, temperature showing 5 bars bleazie V-Strom Service and Maintenance Questions and Discussions 3 11-23-2015 11:16 PM
Ravetech Plate, H&B Bars & OEM Stand on Vee 2 Dave.A V-Strom Modifications and Performance 0 08-15-2015 07:02 PM
