Clutch slipping - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #1 of 35 Old 04-09-2019, 10:51 AM Thread Starter
Clutch slipping
Hey guys, so my used 'Wee is at 15000 km and I'm out of the easy adjustment free play. The clutch slips if I accelerate quickly. My question is should I order a clutch kit and change it out when I go in there, or is 15000 low enough that I just need to do the adjustment?
Lars is offline
post #2 of 35 Old 04-09-2019, 10:57 AM
V-Tom's Avatar
It's very rare to have a slipping clutch that early in a Strom's life. (My clutches never slipped on any of my Stroms.)
Almost guaranteed to be an adjustment and my initial suspicion is that the cable is adjusted too tight. Have you checked for play in the cable? Is the cable caught in it's routing so that it pulls itself too tight?
The adjustment for the clutch is within the right side housing. I don't know how to do it as I never needed it in 139,500 km on my 2012 DL650. I am sure others will chip in shortly.
..Tom
Big B likes this.
SMIDSY detailed report.
V-Tom is offline
post #3 of 35 Old 04-09-2019, 11:25 AM
eff
eff's Avatar
My first reaction is that you shouldn't be having this issue with such low mileage. What are you running for oil?
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #4 of 35 Old 04-09-2019, 11:28 AM
There is an exact method for adjusting the clutches. The 2004-2011 are different from the 2012+. Look up those procedures and follow them.
No, you should not need a new clutch at 15,000 kms. But if not adjusted correctly and ridden a while that might not be the case.
Big B, V-Tom, itlives and 2 others like this.
realshelby is online now
post #5 of 35 Old 04-09-2019, 11:39 AM Thread Starter
I've been using the manufacturer recommended synthetic oil, don't have the bottle near me. But what the guy I bought it from used, who knows.
And thanks for the info, I'll try and do the adjustment first before getting the kit.
Lars is offline
post #6 of 35 Old 04-10-2019, 03:46 AM
Gert's Avatar
@ Lars, walk through the steps that you followed to readjust your bike clutch. Could be that you may have missed a step.
Gert is offline
post #7 of 35 Old 04-10-2019, 08:54 AM
Brockie's Avatar
Hi Lars, at your mileage the bike should not need a new clutch OR a clutch adjustment.
Can you be sure that motorcycle specific engine oil has been used? Some automobile oils can have additives that are not compatable with wet clutches.
If there is any doubt I would purchase some motorcycle specific 10W40 synthetic or semi-synthetic oil, a new oil filter, and change the oil and filter.
My other thought is that the bike was sold as there was a problem, perhaps one caused by the previous owner. I'm assuming that the bike is new to you and bought privately as otherwise, the dealer should sort it out for you.
I have attached the information you need to adjust the cable and clutch correctly - but you must first be very sure that the oil is the correct oil. Some clear images of the throttle and activator end of the cable might help to diagnose your problem.
itlives, Webfors and hoggdoc like this.
Brockie is online now
post #8 of 35 Old 04-13-2019, 03:33 PM Thread Starter
Currently, there's is definitely motorcycle synthetic oil in it, I did an oil change right after I bought it. Before that, who knows? Probably, he worked in a bike shop.
As for the method I used to adjust the Freeplay, I only attempted to adjust on the handlebars, I didn't adjust anything under the clutch cover. That will be my next job.
Lars is offline
post #9 of 35 Old 04-13-2019, 03:38 PM Thread Starter
Besides on the handlebars, is there a place to adjust the free play that doesn't draining fluids? Just to make sure Im not missing something obvious.
Lars is offline
post #10 of 35 Old 04-13-2019, 03:39 PM
blaustrom's Avatar
If there is no free play in the clutch cable, you can adjust it at the top AND at the bottom. If there is no adjustment remaining at the top then the bottom adjuster is too far out. Bring it back some so you get some adjustment range at the top, set it to the specified couple of mm at the lever and see if that fixes the problem.
see here for details: https://www.stromtrooper.com/713846-post6.html
https://www.v-strom.co.uk/smf/index.php?topic=21656.0
Clutch adjustment is outside the engine case, so no oil comes out! Whiles you have the cover off clean out the area since it's most likely gummed up with chain lube and grit.
K9 Wee likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
Unknown ongoing clutch issue SkidmarkRVA DL1000 from 2002-2012 16 01-19-2017 08:19 AM
26K on 2006 Wee, clutch slipping? gibbage DL650 and DL650A - 2004 to 2011 8 03-17-2014 04:08 AM
Clutch Grab Strange Dog DL1000 from 2002-2012 19 03-28-2013 10:26 PM
Slipping clutch - did I really wear it out in 13,000km? obstacle DL650 and DL650A - 2004 to 2011 13 11-28-2012 05:31 AM
Clutch slipping after using mobil 1 synthetic SOLDBYLARRY General V-Strom Discussion 30 03-01-2009 10:19 AM
