Help Needed, "Clunk" From Neutral to First - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 19 Old 04-08-2019, 09:33 PM Thread Starter
I'm new to motorcycles and picked up a 2012 650 Vstrom with 10K on it. It has a noticeable 'clunk' noise going from neutral to 1st. Is there an adjustment I can make to correct this or should I take it to a mechanic?
If it matters, I noticed this when it was stationary, but not when riding. But, I was completely focused on learning to ride this bike, so it's possible it was doing it then and I just didn't notice it. I can check that out in my next ride if that matters.
I tried searching the forums here, but couldn't find anything.
All help appreciated!
Unionguy is offline
post #2 of 19 Old 04-08-2019, 09:36 PM
Yup, normal, you're good.
Hatchi is offline
post #3 of 19 Old 04-08-2019, 09:49 PM
Worry if if it doesn't clunk.
iamsmiling likes this.
gdrew is online now
post #4 of 19 Old 04-08-2019, 10:08 PM Thread Starter
Really, normal? Wow, that's a relief. Thanks!!
Unionguy is offline
post #5 of 19 Old 04-08-2019, 11:13 PM
blaustrom's Avatar
Welcome to the forum!
"They all do this" Ö but in this case it's true!
When you pull in the clutch there is still drag between the plates so the tranny input shaft is not stationary. Thus shifting it into 1st gear (that is stationary) there will be a noise when the two meet. Most pronounced when you start cold in the morning (more drag of the clutch). You can avoid that first loud clunk by starting the engine in gear with the clutch pulled in. The bike will want to inch forward a little under those conditions.
Best is to wear earplugs and not worry about this but focus on ATGATT and defensive driving watching the cars, they are out to get you.
eff and Unionguy like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 19 Old 04-09-2019, 12:50 AM
Webfors's Avatar
Normal. At a stop light I'll pull the clutch in a little early to reduce the engagement when I finally put it in gear.
Drive it, love it, and it will love you back!
Two wheelz for realz!
Webfors is offline
post #7 of 19 Old 04-09-2019, 04:00 AM
joethebike's Avatar
Once the engine is warm do all your starts in gear with the clutch in, the warm oil will mean the clutch plates are quite free and there is no creep when you hit the starter button.
Funny thing is my bike will often go into first from neutral on a cold start without the slightest clunk but mostly it clunks on a cold start.
2005 DL 650 - 117,500m
1972 Suzuki T350 - about 105,000 miles (including 2 Castrol 6 Hour Races)
1982 Honda CX500EC - 260,500km
All owned from new
joethebike is offline
post #8 of 19 Old 04-09-2019, 08:02 AM Thread Starter
thanks again to everyone for the prompt and informative replies!
Unionguy is offline
post #9 of 19 Old 04-09-2019, 10:14 AM
Check your chain to make sure it's not too tight.
Too tight a chain will cause more of a clunk.
Chain on the loose side is better.
Unionguy likes this.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #10 of 19 Old 04-09-2019, 10:23 AM
Yes, it's normal. But make sure the engine has the correct weight oil in it and the clutch cable lever has the correct amount of free play via the cable adjustment.
MAZ4ME is offline
Mystery Neutral pop78 DL650 and DL650A - 2004 to 2011 11 04-18-2013 02:01 PM
Coasting in Neutral. Strange Dog General V-Strom Discussion 54 06-16-2012 11:04 PM
Neutral light power relay danketchpel Maintenance, Tech and Products. 11 10-27-2011 12:12 AM
Neutral light grew a mind of it's own aTuWitty DL1000 from 2002-2012 7 10-18-2011 10:13 AM
