Help Needed, "Clunk" From Neutral to First - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #11 of 19 Old 04-09-2019, 02:04 PM Thread Starter
Thanks! I will check those out as well. I need to get an owner's manual, but somewhere on here it said correct chain slack was .8-1" and correct freeplay at the clutch lever was 10-15mm (on the outside). Anyone know if those are correct for a 2012 650?
thanks again to everyone for the help!
Unionguy is offline
post #12 of 19 Old 04-09-2019, 03:44 PM
Close. My 2012 DL650 service manual states 0.4" - 0.6" (15 - 20 mm) of clutch cable play and 0.8" - 1.2" (20 - 30 mm) of chain slack.
thirdofthree is offline
post #13 of 19 Old 04-09-2019, 04:53 PM
Boise Jim's Avatar
Mine clunked like that, but when I switched over to Amsoil, that changed a ton. Shifting is a lot smoother now.
Instructor, Idaho STAR Motorcycle Safety Program
Boise Jim is offline
post #14 of 19 Old 04-09-2019, 08:30 PM
STCorndog's Avatar
Yuup, my Strom did it and my Tenere does to. I do not like it and avoid doing it.
Clunk means impact in the gear box pure and simple.
To avoid it, you can do a few things. Double pump the clutch right before the shift from N to 1. Leave in gear as much as possible and use the clutch while waiting at lights (it is much safer anyway). And when my bike is warm, I stick it in first before I start it, then pull the clutch in before I thumb the starter.
Yes, some OCD people avoid doing it. Sorry, it is a disease. Therapy has not helped me.
STCorndog is offline
post #15 of 19 Old 04-09-2019, 09:11 PM
It’s a once per ride startup reminder that you are operating powerful machinery.
Seriously I guess it’s a wet clutch thing, not releasing completely. You should have heard my old Sportster, CLUNCK! Did it for 20 years no problem. You can avoid by starting in first gear but then it’s hard to back up, for the same reason.
Hogges is offline
post #16 of 19 Old 04-09-2019, 11:51 PM
tucsonray's Avatar
Go ride a Harley. You'll barley notice the shift on the vstrom after that.
Boise Jim likes this.
tucsonray is offline
post #17 of 19 Old 04-09-2019, 11:55 PM
JonathanAU's Avatar
True, pick up a harley, make sure it's an old one, there is little you will hear with loud pipes and other pieces falling off the bike
JonathanAU is offline
post #18 of 19 Old 04-10-2019, 04:28 PM
If you blip the throttle after pulling in the clutch lever, that can help break the clutch plates free from each other.
Often that isn't necessary, and if you wait long enough after pulling in the lever, the transmission input shaft will have stopped turning completely. At that point you may find it difficult to get the bike to shift into first, as (generally speaking) you can only shift when at least one of the shafts is spinning).
Usually, even with the clutch lever pulled in for a while, there is still enough drag to keep the input shaft spinning slowly, enough that you can shift, but not enough to produce a big clunk.
V-Strom Ry 2 is offline
post #19 of 19 Old 04-11-2019, 08:40 AM Thread Starter
Thanks all! I did add some freeplay to the clutch lever, it had very little. I'll check the chain this weekend too. Thanks for all the help!
Unionguy is offline
Mystery Neutral pop78 DL650 and DL650A - 2004 to 2011 11 04-18-2013 02:01 PM
Coasting in Neutral. Strange Dog General V-Strom Discussion 54 06-16-2012 11:04 PM
Neutral light power relay danketchpel Maintenance, Tech and Products. 11 10-27-2011 12:12 AM
Neutral light grew a mind of it's own aTuWitty DL1000 from 2002-2012 7 10-18-2011 10:13 AM
