Starter switch board - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-05-2019, 02:24 PM Thread Starter
so the actual board that the four wires are grounded to is broken between the headlight setting and the start setting on my bike.
is there a way to replace just this item or do I have to order an entire handlebar switch assembly?
Sent from my moto x4 using Tapatalk
t-dubc is offline
post #2 of 9 Old 04-05-2019, 02:45 PM
locoblanco's Avatar
I think it's only available as the whole assembly, but for the break you describe I would try a drop of super glue as long as the electrical part is undamaged.
locoblanco is offline
post #3 of 9 Old 04-10-2019, 07:47 AM Thread Starter
My solution was to solder the headlight wires together on the switch.
So far so good.
I lose the ability to have the headlights shut be off when starting.
I have the Eastern beaver relay setup with the switching(uninstalled).
After that I should be good.
I'll post more if I have problems
Not great pics but should convey the concept.
t-dubc is offline
post #4 of 9 Old 05-23-2019, 11:54 AM Thread Starter
This has been working just fine.no problems at all
t-dubc is offline
post #5 of 9 Old 05-23-2019, 07:50 PM
locoblanco's Avatar
Does the fix you did have any effect on the hi beam/lo beam switching? I'm guessing not as that switch is on the other side.
post #6 of 9 Old 08-06-2019, 11:41 AM Thread Starter
Nope everything's works exactly the way it did before
t-dubc is offline
post #7 of 9 Old 08-06-2019, 12:21 PM
The EB set up is good. I got the extra cut off switch for one headlight too. And I installed LED's, cheap'os from China that are nice and white bright.
That gives a bit of power available for other toys.
post #8 of 9 Old 08-07-2019, 11:05 AM Thread Starter
I have the EB set up to I just haven't installed it yet but still doesn't fix the actual wearing out problem with the starter board.
Does it give you a number of switching options you didn't have before though.
t-dubc is offline
post #9 of 9 Old 08-16-2019, 12:27 AM
Gerhardus's Avatar
Have you looked at easternbeaver.com. I'm not affiliated with the site, but a student of mine pointed me to it after my starter button broke for the second time.
Gerhardus is offline
How a clutch switch cost me $600. Grungydan General V-Strom Discussion 36 08-10-2018 06:11 AM
Is it the starter solenoid? Craig S DL650A - 2012-2016 7 04-28-2017 09:30 AM
Another lights out starter switch post 2011christrom Maintenance, Tech and Products. 5 04-10-2016 12:43 AM
Starter switch replacement novichek Maintenance How-to 15 04-08-2015 03:14 PM
Potential big PIA prevented due to this board tonight. PhotoBiker General V-Strom Discussion 1 09-19-2009 10:12 PM
