LED blinkers on the cheap - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 2 Post By Rolex
  • 1 Post By itlives
  • 2 Post By Webfors
  • 1 Post By itlives
post #1 of 8 Old 04-04-2019, 09:38 PM Thread Starter
itlives's Avatar
Granted, I'm new here and there's a lot I don't know, but (there's always a but) why would one buy the Suzuki led turn signal kit for over $200 when you can piece it together for so much less? I just bought a 7-pin relay made for Suki and it works on both led and standard bulbs.it cost $11]
With some led light replacements, you're done!
Sure beats this! -
http://www.ebay.com/itm/Suzuki-Genui...edirect=mobile
Edit- I had a link to the relay on Amazon but took it down because it also brought up my account.
itlives is offline
post #2 of 8 Old 04-04-2019, 10:36 PM
Rolex's Avatar
I assume your system works like mine.
Be aware with the aftermarket relay you will not get any indication like a fast or slow flash if one if your turn signals is not working.
itlives and V-Harry like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 8 Old 04-05-2019, 11:26 AM Thread Starter
itlives's Avatar
Rolex, didnt think of that. But led's rarely go out!
I bought a crap load of led bulbs for my camper(s) and have more than a lifetimes worth! I still carry extra bulbs...
DesertBike likes this.
itlives is offline
post #4 of 8 Old 04-11-2019, 07:36 AM
Cheap leds are crap, the mostly contain 5mm or 3mm leds, I've been through many. You need high brightness leds with a bright output. I bit the bullet and picked up some Yamaha ones and they're bright, you get that laser diode shine when you look at them from a distance. You get what you paid for.
medve is offline
post #5 of 8 Old 04-11-2019, 10:37 AM
I got a cheap replacement flasher compatible with LEDs for $15, a pair of high brightness / output LED 1156 bulbs for $25, and painted the inside of the turn signal housing white with a rattle can I had in the basement.
I indeed got what a paid for: a relatively cheap solution much brighter and more noticeable than stock 1156 bulbs both up-close and at a distance.
I agree with medve's sentiment of getting what you pay for relative to the aftermarket complete-replacement LED turn signals. The cheap options have woefully low output. That's why I went with the above and couldn't be happier.
(Well, I'll be happier once I convert my turn signals to a super-bright LED module like the Whelen LIN3 or more likely one of the lower cost / higher value options.)
thirdofthree is offline
post #6 of 8 Old 04-16-2019, 09:57 PM Thread Starter
itlives's Avatar
I got my led relay in and put in the last two led blinkers. Im very happy with both the price and quality of my set up. I still need to change out those little lights up front. I have them already but can't get my fat fingers up in there to release them.
Persistence will prevail...but not today.
itlives is offline
post #7 of 8 Old 04-16-2019, 10:01 PM
Webfors's Avatar
I replaced mine with relatively inexpensive LEDs and bought the aftermarket relay from the UK.
Now, don't pistol whip me for what I'm about to say, but a cheap trick to increasing the brightness of my cheap LED bulbs...? Lined the interior of the light fixture with aluminum foil that I crumpled dozens of times to create hundreds of random creases. Glued it in along the back of the fixture, and let me tell you... those bulbs are BRIGHT
But don't do what I did...
thirdofthree and itlives like this.
Two wheelz for realz!
Webfors is offline
post #8 of 8 Old 04-17-2019, 09:59 AM Thread Starter
itlives's Avatar
I did the same. I read where someone painted the inside white but thought aluminum a better answer to the "problem".
You're correct , they are appreciably brighter. I didn't glue mine. I justpressed it in. Works for me!
Webfors likes this.
itlives is offline
Cheap tyres .... but not for us saturn 5 Australia-New Zealand 17 02-06-2014 05:56 AM
V-strom and Being Cheap 1956 CJ-6 General V-Strom Discussion 50 04-17-2013 01:16 AM
LED aux. lights, on the cheap. swingset Maintenance, Tech and Products. 22 04-05-2009 10:17 PM
Cheap Center Stand! Ruggybuggy DL650 and DL650A - 2004 to 2011 12 01-01-2009 01:52 PM
