16 tooth and chain length - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 16 Old 04-02-2019, 03:20 PM Thread Starter
itlives's Avatar
For those that have put a 16 tooth front sprocket on . Did you have to lengthen the chain?
Thanks, Mike.
itlives is offline
post #2 of 16 Old 04-02-2019, 03:30 PM
No, stock chain works fine. Stock chain also works for 17t front sprocket.
You will swear you cannot get the sprockets off/on because you cannot get the chain off them. Release the chain tensioners all the way and move axle fully forward. Loosen sprocket nut. Which can be a chore all to itself. Air impact is your friend here, and some heat may be required in really stubborn cases. There is high strength locking compound on these from the factory.
Now that you have the sprocket nut off, work the chain off the BACKSIDE of the sprocket! Normal instinct is to take it off to the outside. That won't work......!!!! Slide sprocket off and put new one on. Work chain on from the backside....and voila!
Motor7, Webfors and Shudman like this.
realshelby is offline
post #3 of 16 Old 04-02-2019, 03:47 PM Thread Starter
itlives's Avatar
Thanks! I had bought a 43 tooth for the rear and the chain is WAY too long. I've never broken a chain apart and didn't want to start with this one!
itlives is offline
post #4 of 16 Old 04-03-2019, 11:26 AM
Slickrock's Avatar
a 16T front socket has been the number one best upgrade for my Wee. I don't go off-road so the gearing is perfect for the road. Speedometer now reads correctly and RMPs are at 5,500 at 75mph. Makes going the speed limit seem like the motor isn't even running.
Slickrock (Dan)
2013 Dl650A and 1983 Honda XL600r Thumper. Lower end of Central Valley, CA.
Slickrock is offline
post #5 of 16 Old 04-03-2019, 11:30 AM
Highwayman2016's Avatar
+ 1 on the 16 tooth front. Makes the bike much better here in the southwest with the high speed limits. Same length chain.
2014 650 Strom
Highwayman2016 is offline
post #6 of 16 Old 04-03-2019, 05:15 PM Thread Starter
itlives's Avatar
That's all good to hear. Once or twice a year I get to really put down some miles (3-5k) in a week. I didn't want to stress the engine too much. My last two bikes were bigger and could take 80 all day easily. I've go be down in size because I'm 63 and don't like picking up big (Super Tenere) loaded bikes when i drop them....and i do.
itlives is offline
post #7 of 16 Old 04-04-2019, 07:59 AM
The 16 tooth won't really be much easier, if any, on the engine. Turns about 350 rpms less ( around that number ) at 70 mph. You, or at least me, will still be turning well over 5,000 rpms most of the day.
My advice is masking tape. Cover the tachometer. Then you don't fret about the rpms'. Plenty here have run these at 6,000+ rpm for tank after tank. We did on the 2004 heading out West. They just eat it up. No worries. Only thing to watch is that some ( for sure not all ) DL 650's will push some oil into the airbox when run at very high rpms for extended periods. Just check your oil a couple times to be sure it isn't doing that.
chicago, Gert, itlives and 1 others like this.
post #8 of 16 Old 04-04-2019, 09:19 AM Thread Starter
itlives's Avatar
realshelby - when I first picked up my Wee, I rode it back to Louisiana from Georgia. I was and still am truly amazed at how smooth the engine runs at 5,000 - 5,500 rpms.
Thanks for the tip on checking the oil.
Webfors likes this.
itlives is offline
post #9 of 16 Old 04-05-2019, 04:54 PM
Webfors's Avatar
I've read a lot of threads on going with 16t. Lots of yays and nays, not sure what to do
I read that it may not be easy on the glee like it was on the wee. Is that correct or did I misread?
Two wheelz for realz!
Webfors is offline
post #10 of 16 Old 04-05-2019, 08:51 PM Thread Starter
itlives's Avatar
You mean putting it on or easy on the engine?
Putting it on(or rather, getting the sprocket off ) looks to be an impact wrench job.
itlives is offline
Broke my chain in 7K miles. Looking at ordering a kit of sprockets and chain. Pele2048 DL650A - 2012-2016 45 08-13-2016 10:41 AM
Chain longevity theory. What do you think? bobbyvstrom General V-Strom Discussion 14 05-12-2015 10:54 AM
Sprockets - 17 and 45t chain length? Waldo DL1000 from 2002-2012 5 10-21-2013 01:17 PM
Chain Adjustment / Side Stand vs. Center ckellyne Maintenance How-to 39 09-01-2013 08:54 AM
