Extra spring appeared... help identify? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 14 Old 03-20-2019, 11:34 AM Thread Starter
After putting new tires on the '12 DL650 yesterday I noticed a small spring laying on the floor near the front of the bike on the right hand side. I can't think of anywhere that it may have some from, does anyone recognize it? Things I did yesterday:
Removed / installed rear wheel to put on new tire.
Removed / installed dogbones to return rear suspension to OEM spec from being lowered 3/4"
Removed / installed front wheel to put on new tire.
Removed front fork cap, spacer sleeve, wash and spring to check to see what spring weight I had.
Adjusted front suspension down to OEM spec from being lowered 3/4".
The only place I can even think that might have a small spring would have been the front calipers or front speed sensor. I'm pretty sure this spring came from a toggle switch that blew apart but I want to make sure no one recognizes it as a critical part
Thanks!
Got the heart attack over and done with - Prudhoe Bay or Bust!
slane6 is offline
post #2 of 14 Old 03-20-2019, 11:54 AM
DLLarry2013's Avatar
I'm guessing the toggle switch. Too small for any thing else. Also nothing you mentioned touching on the Strom would have that spring.
Brockie likes this.
DLLarry2013 is offline
post #3 of 14 Old 03-20-2019, 12:00 PM
dravnx's Avatar
That's called the Oh Shit spring.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #4 of 14 Old 03-20-2019, 12:08 PM
blaustrom's Avatar
I would also vote for the toggle switch. Don't think a spring like this is anywhere you worked on.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 14 Old 03-20-2019, 12:43 PM
You have the rest of that toggle switch to see if there's a place for it? Does your bike have adjustable hand levers and did you take them apart? These levers have a similar spring in the pivot area.
slane6 likes this.
MAZ4ME is offline
post #6 of 14 Old 03-20-2019, 02:46 PM Thread Starter
No shit!
slane6 is offline
post #7 of 14 Old 03-20-2019, 02:47 PM Thread Starter
No adjustable levers. Pretty positive it's from the toggle switch, just wanting to make sure.
slane6 is offline
post #8 of 14 Old 03-20-2019, 09:11 PM
Dija work on the shock pretension handle? there are a couple 3 ball bearings and springs in there.
slane6 likes this.
post #9 of 14 Old 03-20-2019, 09:14 PM
BigSky's Avatar
No help I know; but, did you recently do a trigger job on a rifle recently?
Motor7 and slane6 like this.
BigSky is offline
post #10 of 14 Old 03-21-2019, 09:38 AM
itlives's Avatar
Looks like a ball point pen spring to me.....could have been lost and lodged and knocked loose during the work?
itlives is offline
RaceTech rear spring installation on OEM shock questions Maco DL1000 from 2002-2012 16 03-03-2016 07:44 PM
REAR spring rate: WHAT IS RIGHT!?!? SWriverstone Suspension and Tire Tech 20 11-25-2013 10:01 PM
Summer Central Florida Spring Ride Cpope Florida Troopers 153 10-15-2008 09:11 PM
rear shock spring rcacs V-Strom Modifications and Performance 0 04-14-2008 02:52 PM
