Trying to find replacement rear brake spring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By locoblanco
  • 1 Post By bajakirch
post #1 of 5 Old 03-18-2019, 04:55 PM Thread Starter
bajakirch's Avatar
In remounting my rear tire, I mucked up the rear brake caliper spring that sits on the caliper mounting bracket. I've been looking at the normal parts sources, and I can't seem to find a way to purchase the spring only. Bike Bandit etc. only seem to sell the bracket as a unit, and that's going to be over $70.
This is the part in question.
bajakirch is offline
post #2 of 5 Old 03-18-2019, 04:59 PM
Can this spring be carefully straightened out?
MAZ4ME is offline
post #3 of 5 Old 03-18-2019, 05:11 PM Thread Starter
bajakirch's Avatar
My wife asked the same question.
Given that it's a part for the brake system, I'm not sure how safe it would be to 'good-enough' it.
post #4 of 5 Old 03-18-2019, 06:29 PM
locoblanco's Avatar
It's not actually a spring, just a metal slider suface to sit between the end of the pads and the aluminum bracket, presumably to keep the steel plate of the pads from gouging the aluminum. It should be ok if you can gently straighten it so it sits flat again. It's not really under pressure.
eff likes this.
locoblanco is offline
post #5 of 5 Old 03-19-2019, 04:05 PM Thread Starter
bajakirch's Avatar
Thanks for the advice.
I ended up using a combination of needle-nose pliers, my shop vice, and a small hammer to get it approximately into the original shape. It was good enough to put everything back together, and the brake appears to work fine.
locoblanco likes this.
Rear spring swap ABS wee Fireclimber Maintenance, Tech and Products. 3 02-09-2016 05:23 AM
Re-assemble Rear Brake Pedal Spring sawdura DL650A - 2012-2016 2 04-24-2015 11:19 PM
Dragging Rear Brake After Pad Replacement And Fluid Flush portabill DL650 and DL650A - 2004 to 2011 25 02-26-2014 05:51 PM
SV Racing Parts, June and July Photo Ride Contest, SS Brake Lines Give Away SV Racing Parts SV Racing Parts 96 05-20-2011 11:35 AM
