HELP NEEDED Swingarm pivotal bearing removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 11 Old 03-18-2019, 04:36 PM Thread Starter
hi there, I'm stuck with swingarm pivot bearings seazed to the swingarm (the ones holding doggbones and connecting swingarm to the shock linkage). Is there a hole trough the swingarm so I could push those bearings all the way trough? It seems to me there is a base for the bearing in the middle of the swingarm?! In that case what tool I need to get those out please?! I almost managed to nock one out but realised the outer shelve of the bearings is still stuck inside the swingarm. This sucks, any advice greatly appreciated. If I can get them out without removing swingarm, that would be great as I don't have the tool for swingarm removal.
PS: i had a major issue with collapsing linkage, replaced all including the shock and at the same time upgraded the front fork as well. Now almost there and stuck with those bearings. How can I get those out please?
Sent from my CLT-L09 using Tapatalk
petr_nehyba is offline
post #2 of 11 Old 03-18-2019, 04:38 PM Thread Starter
Just to add is Dl650 abs 2013
post #3 of 11 Old 03-18-2019, 04:56 PM
Go to a hardware store and get a length of 3/8" NC threaded rod, 2 3/8 washers, and 2 nuts. Piece of threaded rod through the bearing, and a 3/8" socket large enough inside to accept the bushing. Small enough socket on the other side to push against the bearing inside the swingarm bore. Washers and nuts on both side, tighten one while holding the other to pull the bushing out of the swingarm. You can use small sections of pipe instead of a socket, and depending on size, you can use 5/15 or 1/4" threaded rod, washers, and nuts instead.
chicago and petr_nehyba like this.
MAZ4ME is offline
post #4 of 11 Old 03-18-2019, 04:59 PM Thread Starter
Yes that would be ideal if there would not be a base for the bearing in the swingarm?!I'm not sure but it seems there is a base from what I could see there, also on the picture. That would not allow me to push the bearing trough. Would you know if there is a bearing base? Thanks very much for coming to help. Appreciate that P
post #5 of 11 Old 03-18-2019, 05:08 PM
2 other alternatives--CAREFULLY Dremel a slot in the bearing, and using an awl, try to collapse the wall you just slotted. Then pull and work the bearing out. Another method--youll need a small slide hammer with an expandable collet on the end proved there is an area behind the bearing for the collet to catch.
Ive had to slot many bearings and bushings. It's time consuming, but it does work. You just want to weaken the wall so that the bearing or bushing can be cracked or collapsed.
petr_nehyba likes this.
MAZ4ME is offline
post #6 of 11 Old 03-18-2019, 05:57 PM Thread Starter
That's a great advice, thank you very much! I'll get the dremel tool and try it that way. Many thanks indeed!! Best wishes P
post #7 of 11 Old 03-18-2019, 07:33 PM
HAPPY to help!
MAZ4ME is offline
post #8 of 11 Old 03-19-2019, 08:53 AM Thread Starter
HAPPY to help!
Victory is cake Dremel thanks again Maz4me!!
chicago, Spec and eff like this.
post #9 of 11 Old 03-19-2019, 10:31 AM
petr, glad it worked out for you!
MAZ4ME is offline
post #10 of 11 Old 03-19-2019, 03:27 PM Thread Starter
A simple tool made to get new bearings in. Much better than hammer all sorted now, only can hear her ticking. Pretty sure valve clearance adjustment needed. But won't do that, have had enough for now. Will have to book in to a garage. Thanks again and best wishes P
Givi screen removal advice needed Traveler General V-Strom Discussion 6 09-22-2012 08:43 PM
DL 650 How To: Make Homemade Swingarm Removal Tools Black Lab Maintenance How-to 14 05-07-2012 03:22 AM
How to grip removal for heat elements needed viclava V-Strom Modifications and Performance 6 10-12-2010 07:52 PM
Windshield removal help needed OpusX DL650 and DL650A - 2004 to 2011 5 08-29-2008 12:17 PM
