Eastern Beaver PC-8 install problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By V-Tom
  • 2 Post By scritch
post #1 of 6 Old 03-18-2019, 02:24 PM Thread Starter
Well, I took advantage of a beautiful Sunday in Seattle to install my new Eastern Beaver PC-8. Got it all done up to the point where I needed to hook the relay wire into the brake lamp wire using the included connectors. The problem is that I can't find the brake light connector for the life of me. Eastern Beaver has a photo of a connector which he says is near the rear gas tank mounting bracket, but I think his bracket looks different than mine, so I'm not sure I'm looking in the right place. I did see a connector the color that matches the ones on the PC-8 wire, and maybe the correct shape, buried under the tank between cable bundles and hoses. Am I looking in the right place?
It's really difficult to know where to look. Wires go in and out of taped-up bundles, so it's impossible to trace circuits from one end of the frame to the other.
I have a 2013 DL650A.
(PS: I went to go for a ride after I put everything back together, and when I turned the key, no fuel pump! No start! Just check engine light. I got really scared, and checked all of my wiring connections again, but all was fine. Then I realized that I still had the kickstand down.)
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
post #2 of 6 Old 03-18-2019, 08:02 PM
V-Tom's Avatar
It has been about 7 years since I did what you are doing on my 2012 DL650.
I don't recall for sure but think it might be tucked under the bracket where the rear gas tank bolt goes or a bit further back on the right side beside the battery area.
It's there somewhere just need to look harder.
..Tom
Motor7 likes this.
SMIDSY detailed report.
V-Tom is offline
post #3 of 6 Old 03-20-2019, 05:54 PM Thread Starter
Found it! Had to take the fuel tank almost off, but I got it.
V-Tom and VstromGrin like this.
scritch is offline
post #4 of 6 Old 03-26-2019, 12:03 PM
EGGSS's Avatar
i was gonna say i took the tank off for mine ::thumbs up ::
96 zx6 - sold
01 f4i -sold
02 R6 -sold
10 Gsxr6 - sold
13 dl650A -
EGGSS is offline
post #5 of 6 Old 03-26-2019, 12:10 PM
eff
eff's Avatar
I found mine before I bought my PC8 when I was checking the valve clearance. Mine was tucked in under the coolant overflow tank so to get at it later all I needed to do was lift the tank and remove the overflow tank. I wish I took a couple of pictures since they would have helped a few folks on here.
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #6 of 6 Old 03-28-2019, 09:12 PM
VstromGrin's Avatar
I need to do this soon too, those pics would have helped alright.
2013 SUZUKI DL650 AL2
VstromGrin is offline
ABS switch from Eastern Beaver - need help Scott_J DL650 and DL650A - 2004 to 2011 5 02-07-2018 12:53 PM
Installing Eastern Beaver Handlebar Wiring Extensions WeePilot DL650A - 2012-2016 12 04-21-2015 06:46 AM
Eastern Beaver install issue RShrimp DL650 and DL650A - 2004 to 2011 6 06-29-2011 10:04 PM
Eastern Beaver - Great Service! CHIA General V-Strom Discussion 0 11-03-2009 01:53 PM
Anyone install a fusebox with Eastern Beaver relay set up? BigHerm DL1000 from 2002-2012 8 10-17-2009 11:05 AM
